Old 09-25-2003, 05:15 PM   #1
mach158
Fixing 4 wheel drive on 89
I am looking at an 89 chevy 1500 4x4 and was told it has a broken front axle. Was told the part will cost $106. How hard will it be to fix this? The truck is still driveable just doesn't engage in to 4x4. I'm very mechanically inclined and do all my own work on my cars but wanna know what i'm getting into before i start so i also make sure to have everything i may need.
I have seen a 4x4 truck and its working just never tore into one but i can't see it being to difficult.
On a scale of 1 to 10 10 being hardest what is this rated and what kind of job would be similair to it, like would pulling an engine be the same or harder or something like that.
Thnaks in advance for any help or ideas you can shed on the subject.
mach158 is offline   Reply With Quote
Old 09-25-2003, 06:34 PM   #2
Stingray42
Woot.
Stingray42's Avatar
what is broken in it? That will help the guys here help you out.
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 09-25-2003, 06:47 PM   #3
mach158
I'm not sure really, the truck is at a car dealer and the guy told me it had a broken front axle it was priced at like $106 for the peice that is broke. And this peice allows it to not go into 4x4 i guess.
Sorry i guess i can't really offer any more information till i go look at the truck tomorrow.
I figure it can't been to hard as i have done alot of car stuff like engine swaps, tearing down rearends in cars and so forth, i guess when i figure out the exact problem and i need help i will ask unless someone may have an idea of what is wrong with it.
Old 09-25-2003, 08:04 PM   #4
trukkers69
Sounds like Bullshat to me if thats all it was gonna cost they would fix it and get more money from it.
But if the part only costs 106 it's probably the little "sensor engagement thingy" ( couldn't think of the name of that part if my a$$ was on fire right now) that the electrical wires hook up to on the differential case.
EXPERIMENTAL STAGES OF SANITY
_____________________________
Run whatcha brung, and hope you brung enuff
trukkers69 is offline   Reply With Quote
Old 09-25-2003, 11:30 PM   #5
Scrub
Collector of rusty Items
Scrub's Avatar
Offer the crooked bastard 106 bucks more and tell him to fix it. I agree with the bull**** declaration.
Go look somewhere else. This dealer is yanking your chain.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 09-26-2003, 01:27 AM   #6
1969 GMC
1969 GMC's Avatar
thats what the wonderful world of IFS will get you. try for something with a solid front axle that won't break if you look at it the wrong way. and yeah, $106 for an IFS piece? haha. I'd say no thanks.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-26-2003, 04:25 PM   #7
alf4444
alf4444's Avatar
$106 is about dealer cost for a CV joint isn't if that is whats wrong it is an easy fix.
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 09-27-2003, 10:20 AM   #8
mach158
The actual driver side front axle is broke and not there anymore. So i need a new axle the part that goes from center peice to tire. If no one knows what i mean i can get pictures.
How much am i looking at to fix this? I will be doing work myself so price just parts.
Old 09-29-2003, 02:27 PM   #9
sakohntr
sakohntr's Avatar
where
Where are you located (not in your signature)? I probably have an axle.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 09-29-2003, 04:39 PM   #10
mach158
I'm located in Wapello, Iowa.
I may have a lead on the parts i need. If not i will let ya know and hopefully you have them.
I not only need the axle i need any joints that connect the axle to the center section and then to the wheel.
Let me know though if you have them and how much you want for it.
If you want you can e-mail me directly at mach158@hotmail.com
Old 09-29-2003, 08:17 PM   #11
trukkers69
My 2 cents
Well if your gonna buy it broke then go ahead and get NEW parts to fix it with . The axle should come complete from differential flange all the way to splined outer shaft. I'ts not that big of a job but it's a pain in the arse to have to do it twice because of cheap parts. Jeff
