where to find correct distributor 86 c10 with esc and vacuum
I'm messing with my recently acquired non-running 1986 C10 silverado 305. I have no spark, but i do have power at the BATT terminal on the distributor. I was going to replace the whole distributor assembly, but i'm having trouble finding the right one. Most have either Vacuum or ESC connector, but not both. RockAuto has one (D2086) that appears correct, but doesn't include the coil on top.
I know i can remove ESC, but I think i'd like to keep it "correct".... anybody have tips on where to find the right one? thanks! |
Re: where to find correct distributor 86 c10 with esc and vacuum
Scratch this. I bypassed ESC by jumpering the 2 wires and the beast runs. Started up immediately!!! Will start another thread to ask about ESC. Feel free however, to post any helpful info, i still may need it some day....
Master Hater
Its a good system when it works.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
GM dear any of the GM after market venders IE: Jegs, LMC, Classic Parts, just to name a few.
Bone Yard 84-86 GM trucks 305,350 Chev motor cars 84-87 chev Motor 305,350 with this stye dist. plug on the dist. http://www.73-87.com/7387garage/driv...repl/plug1.jpg Or rebuild it yours self or send it out to Performance Distributors
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
follow up for searches. replaced ignition module inside distributor, and ESC with a new one, and truck runs! yay! will always keep a bypass wire around in the glovebox!
| Bookmarks |
