03-29-2016, 06:29 PM | #1 |
Master Cylinder ID help
Just picked up a 68 SWB ,The PO did a 5 lug disc brake conversion at some point, The master cylinder is leaking from where it bolts to the booster and also the cap gasket .
I need to replace this master cylinder but need help on the Identification of it . |
03-29-2016, 07:03 PM | #2 |
Re: Master Cylinder ID help
Just match it at the parts place being as they will want a core, or take your pic's with you and check it that way.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-29-2016, 07:04 PM | #3 |
Old member
Go to the parts store and ask for a Disc/drum master for a 71 are 72 either should work just fine.
