Old 03-29-2016, 09:42 PM   #1
70c10guy
out of curiosity...
Been reading lots of threads lately and I always pass by some about cut rear coil springs and have me thinking. Iknow I can cut the fronts and be comfortable but the rear? How many can be cut off the front til the control arm is on a cut bump stop? Who's running cut rear stock coil spring out there and what did you cut off?
70c10guy is offline   Reply With Quote
Old 03-30-2016, 12:18 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: out of curiosity...
I don't think you can successfully cut the rears unless you have a spring shop in your area that can re-taper the coils. The top and bottom of the coils are smaller so that the bracket that bolts the spring to the trailing arms and frame will fit it..... I think cutting one full coil off will drop the front 2". This is variable depending on how weak your springs are.
LockDoc
Leon
Old 03-30-2016, 12:10 PM   #3
michael bustamante
michael bustamante's Avatar
more than likely all you could really do to rig the rear spring is heat it
1967custom
michael bustamante is offline   Reply With Quote
Old 03-30-2016, 01:04 PM   #4
DBK81
DBK81's Avatar
I've cut springs before, and it never turns out well, for the minimal cost of a set of drop springs I don't understand why people don't just replace them. To each thier own I suppose. I've drop C10's with cut springs and with replacement drop springs and the ride is way worse with the cut spring aplication.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
