Old 03-30-2016, 03:07 PM   #1
retro4now
Window Glass Won't stay in track
I just changed the driver's window regulator in my 71 GMC. No more vise grips..Yay!
But..... Now my glass doesn't want to stay in the track. It rolls up fine, but when I try to roll it down the glass stays up and the track comes on down.
Any suggestions? I thought it went back together ok.
Gerry
Albuquerque, NM
retro4now is offline   Reply With Quote
Old 03-30-2016, 04:28 PM   #2
Lowenuf
Lowenuf's Avatar
Re: Window Glass Won't stay in track
Is the glass staying in the metal channel that connects to the regulator? And you made sure that all three rollers seated in the tracks?
Lowenuf is offline   Reply With Quote
Old 03-30-2016, 04:30 PM   #3
46stude
Sounds like the gasket between the glass & "cradle" it sets in is gone. I assume you put your original glass into the new regulator?
46stude is offline   Reply With Quote
Old 03-30-2016, 04:52 PM   #4
leddzepp
Moderator
leddzepp's Avatar
You need to seal the window into the channel with glass setting tape. The truck shop in orange is where I was able to find some. Not sure how many other vendors carry it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-30-2016, 06:17 PM   #5
michael bustamante
michael bustamante's Avatar
take the inside door panal off and roll the window down. see if the track comes off the rollers or if the window slides out of the metal retainer track. or maybe the rear track is too tight. loosen the bolts and readjust the window trackes that lead down into the door
1967custom
michael bustamante is offline   Reply With Quote
Old 03-30-2016, 11:15 PM   #6
Ol red 71
I used a product from oreilys called window weld to seat the glass into the channel that holds the bottom of the glass. After doing so, roll the window up and don't touch it for 3-4 days at least.
1971 c20 LWB Fleet 2wd
'working' Add-on AC & Working heat/defrost
manual transmission w/ Power steering & power brakes
Family owned since 1971
____________________________________
“Life is rough so you gotta be tough” - Johnny Cash
Ol red 71 is offline   Reply With Quote
Old 03-31-2016, 06:35 AM   #7
retro4now
Thanks guys. The glass is not staying in the lower channel. When I roll the window down, the glass stays and the channel comes down withe regulator. So it sounds like it needs some sort of glue or tape. I'll look into some of the products you suggested.
Thanks again
Gerry
Old 03-31-2016, 09:48 AM   #8
46stude
I used an old bicycle tube in the channel when I swapped my regulator a while back. Hasn't come out yet.
Old 03-31-2016, 01:29 PM   #9
Grumpy old man
Grumpy old man's Avatar
Use windshield setting urathane lay a bead in the glass channel then roll the window up to dry overnite .
Grumpy old man is offline   Reply With Quote
Old 04-04-2016, 06:43 AM   #10
retro4now
Thanks for all the replies and advice. I used some super sticky weatherstripping adhesive and that did the trick.
Gerry
