![]() Join Date: Jun 2006
So here's the deal, I found a 1972 Chevy 1 ton with dual rear tires that was a dump box/highway truck. Would it be easier to put a step side bed on it and widen the fenders or do a fleetside bed with fender extensions.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Re: Better Route?
A couple of problems to start with.
A C30 has a longer wheelbase than a typical C10 or 20 so the readily available 8' boxes come up short due to a longer cab to axle dimension. So you need to find a Longhorn or 9'stepside box to start with if you are trying to do this as stock as possible. With a stock dual wheel axle, the outer tires are a little wider than a fleetside box. So a flare or creative tire/wheel sizing is needed to tuck them. The inner tire will clear the frame of course but the wells need to be extended inboard a lot. On a stepside the outer fenders are slightly narrower than a fleetside making the tuck a little more dificult. A widened fender or fender to bed spacer is probably the best way to handle that and adding narrowed fleetside wheelhousing should give you the inner clearance needed. Either way you end up really narrow between the wheelhousings like a mini truck and nothing fits. There are other options of course like the typical scabbed on stepside fenders that usually IMHO look too wide and flat against a fleetside bed. You can also use a later wide track dually axle and just push everything outboard from the stock srw location and fender or flair to suit.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: Better Route?
The easiest thing to do is leave it as a dump truck and have something cool and useful
Re: Better Route?
Checkout project "Meet Homer" 3/16/2016. That might give you a new to look at the project you have in mind.
Andy |
Re: Better Route?
Its a mini dump bed of about 4 feet with a big ugly utility box in front of that. Thanks for the answers I can fab up anything since custom painting means custom body work in some cases. I did a 56 International 4X4 dually with widened stepside fenders for a customer.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock Last edited by BigDan3131; 03-31-2016 at 02:47 PM. |
Re: Better Route?
I was faced with this exact same dilemma last year (see "Meet Homer" in projects and builds). I simply widened the bed header panels and tailgate. Tailgate was the worse part. Kinda cool finished product (at least Me and a few others thought so).
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Re: Better Route?
Some years back, there was a pic of a tow truck on here that had this kind of axle set up, and there were step-fender extensions--some 4" to 6" wide--bolted between the fenders and the bedsides. Looked factory. The steps angled out to meet the wider fenders. At one time, I had that pic saved, but I think I have lost it over the years.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Re: Better Route?
Here it is ~4", really not an original idea. At one time Dodge used fender spacers on their stepside/utilines with a drw option.
laying low
![]() Join Date: Mar 2001
Re: Better Route?
Build yourself a neat flatbed.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: Better Route?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Better Route?
That's the other option, but knowing myself it would have everything but the kitchen sink welded on to it.
![]() Join Date: May 2013
Re: Better Route?
Looks awesome
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#13 |
Re: Better Route?
Thanks for posting those pics, Tim!
#14 |
Re: Better Route?
i never get tired of looking at homer. love that truck. i would go the route that cooper did.looks more correct imho
1972 GMC C20 Custom Camper 350/TH350 |
