Old 03-31-2016, 08:52 AM   #1
chazdo2
1971 Signal light problem continues!
I think the problem may lie in the blinker arm assembly. Problem is I don't know how to get the steering wheel off. Any help out there?
chazdo2 is offline   Reply With Quote
Old 03-31-2016, 09:27 AM   #2
1972BlueC20
1972BlueC20's Avatar
Re: 1971 Signal light problem continues!
you have to start by taking those 8 allen bolts off that are around the horn button, then it will become clear how to do the rest.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 03-31-2016, 10:09 AM   #3
chazdo2
Pic probably doesn't show it well but they are off. Wont pull off cant figure how to remove horn button for maybe a bolt that holds the wheel on. Figured someone may have an idea.
Old 03-31-2016, 12:38 PM   #4
1972BlueC20
how hard have you pulled on it?
does the horn button pop out? If so, maybe bolts under it.
sorry I've never had this steering wheel before
Old 03-31-2016, 05:20 PM   #5
chazdo2
Got it!!!! If this helps anybody else. Took the steering wheel off and cleaned up the signal mechanism. Works great now. Thanks for all you guys helping!!!
