03-31-2016, 10:28 AM | #1 |
Breather question?
The breather hole that's on the rear driver side cover. Did you guy run a breather here or a pcv valve to your intake? Is either way better?
03-31-2016, 06:58 PM | #2 |
Re: Breather question?
I am curious what to do with this as well.
the 2003 4.8 I got originally to use in the Suburban had a tube with no valve at all in it. Then I decided to get a 6.0 its a 2002 and it has what looks like a pcv but no valve inside.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-31-2016, 07:54 PM | #3 | |
So, the answer is that it's part of the PCV system. If you have a later engine with a hose nipple on the valve cover, run a hose to a vacuum source. If you have a hole in the cover, you need the fixed orifice "valve" and then just run a hose from the valve to a vacuum source. |
