Old 03-31-2016, 04:47 PM   #1
joeydurango
joeydurango's Avatar
How do you remove the rag joint from the steering box?
Just like the title says... I'm replacing my steering box with a new RedHead quick ratio, and the rag joint is stuck on the old box's shaft. I can see that it's splined... but is there a puller tool for this, or is it just supposed to slide off once the bolt is removed? I've been soaking it in PB Blaster. Before I get medieval with the rubber joint (which is in good shape overall) I wanted to make sure I wasn't missing something obvious. TIA!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 03-31-2016, 05:04 PM   #2
Kell
Kell's Avatar
Re: How do you remove the rag joint from the steering box?
You will probably have to try spreading it apart a bit with a screwdriver and then manhandle it a little, that's what I had to do, mine had been on there for 46 years........
1970 C10 Longbed, 250 Inline 6, 3 OTT
Kell is offline   Reply With Quote
Old 03-31-2016, 05:04 PM   #3
cooperhw
cooperhw's Avatar
I usually put two screwdrivers in the slot on the side and pry them open just a little and then it will slide right off.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-31-2016, 08:50 PM   #4
joeydurango
Thanks guys. Kind of what I figured, but I've been known to figure wrong plenty of times before...
