![]() Join Date: Jan 2013
Crossmember swap with manual steering
Hey all, looking to get sixfo lower without bagging it. I've realized I need drop spindles, which also means disc brakes. I'm wondering if it would be better to do the complete crossmember swap for a later model or just get drop spindles for the stock suspension. I want to keep manual steering. It seems like everyone goes power steering with the crossmember swap.
Also, what would be the easiest way to bring the back down the additional 2.5"-3" to keep it level. I'm currently running TJ coils and 2" blocks. I know I'll have to modify the frame to clear the arms, relocate the upper spring mounts and change the track bar. Do I need to flip the front mounts for the arms?
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
![]() Join Date: Jan 2011
Re: Crossmember swap with manual steering
So what is in the front now and how low is the truck? Pic would be good. And how much lower do you want to go?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
1.5 coils cut in front, TJ springs and 2 inch blocks in the rear
![]() ![]() I'd like to get down a couple more inches.
That far down I would look into notching the crossmember. Getting two more inches down I think will put you a arms very close to the ground.
Jimmy
Chevy addict
Looks good now
