Old 03-31-2016, 06:39 PM   #1
72farmer
Suspension problems on lowered truck
I have a 67 that has been lowered about 4-5".It is not done correctly.I wished I had caught it this winter when I converted it from drum to disc brakes.The PO lowered it by cutting front springs and using DTM1200LL shocks on front and on rear CCP 603-5 springs and Doetsch Tech DT405G shocks.
When I changed the spindles trying to cheap out I used some stock height ones and put it back with the same cut front springs and shocks.Now the suspension is resting on the rubber bump stops.
Could I leave rear suspension along and buy 2.5 drop front spindles and find some stock height springs and start cutting them to match rear height?Will I have to buy another set of shocks.
Other option I was thinking about is leaving stock height spindles and getting stock springs cut to lower front about 2" in front.Then raise rear up to match.Would I have to buy different front and rear shocks?
72farmer is offline   Reply With Quote
Old 03-31-2016, 07:10 PM   #2
DBK81
DBK81's Avatar
Re: Suspension problems on lowered truck
Are you happy with the ride height? Other than the rubbing on bump stop, if so, then trim the bump stop and call it a day.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 03-31-2016, 07:11 PM   #3
DBK81
DBK81's Avatar
O man just looked at the pictures, there isn't much spring left there! They really chopped it up.
