Old 04-01-2016, 10:21 AM   #1
dazza
dazza's Avatar
Tapped or soldered in rad connector?
Seems I have a leak at the lower radiator connection, just happy that I read a thread where someone mentioned using just water for break-in, so no coolant all over the place.
It doesn't look like the connector was soldered in and for some reason I remember somebody saying something about it being just tapped in. Should I pull it and solder? Tap it in? Pull it and take it in for repair?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 04-01-2016, 10:27 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Tapped or soldered in rad connector?
Any that I've worked on have been soldered. If you clean the paint off you should be able to see the solder.
Clean all the paint off with a wire brush & sandpaper, flux it and solder it.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
