Old 04-01-2016, 09:52 PM   #1
DBK81
DBK81's Avatar
Swapping out a TH350 for a 700r4 pros/cons?
Currently have a very fresh, less than 5,000kms TH350 that the PO installed, I'd really like to have an overdrive Trans as I'll do most of my driving on the highway. What are the pro's and cons of doing this swap? Current motor ZZ4 350 Chevy Pref crate motor.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 04-01-2016, 11:46 PM   #2
1972BlueC20
1972BlueC20's Avatar
Re: Swapping out a TH350 for a 700r4 pros/cons?
I'm interested in this too. Subscribed.
I want to do this as well one day.
What modifications are needed and what about the shift linkage and shift indicator lining up
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 04-02-2016, 12:00 AM   #3
DBK81
DBK81's Avatar
It's a relatively easy swap, drive shaft might need to be shortened depending on how long the TH350 a guy has 6" vs 9" tail, I'm running around 400hp and do have a bit of a heavy foot so I just want o be sure the 700r4 will hold up, lord knows the TH350 can handle my 400 and more.
Old 04-02-2016, 12:23 AM   #4
Z10
Z10's Avatar
I did this swap last year with a ZZ4 also. Other than shortening the drive shaft, which cost me about $150 with new u-joints, it was pretty straight forward.
I now have a little over 8000 miles on the engine/trans and it is running great. I'm also turning about 2200 rpm at 70 with a 3:73 rear and getting a hair over 16mpg on the highway with the cruise on.
I'm using a GM rebuilt 700r4 from a 91 Corvette, purchased from a local Buick house.
I'm very pleased.
You can see what I did on my build thread link below.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 04-02-2016, 01:45 AM   #5
DBK81
DBK81's Avatar
I'm very pleased.
That's awesome, I'm also running 373's, I'm going to talk to a local shop to see what they can do and if they are interested in buying my fresh TH350. I just need that OD, it has to happen.
Old 04-02-2016, 11:08 PM   #6
1972BlueC20
What about shift linkage and the gear indicator lining up on the column?
Old 04-03-2016, 12:38 AM   #7
Gatorman
I did a similar swap in a 71 Nova a few years ago. Also was running a crate motor. Go to Bowtie Overdrives. They have everything you will need and are easy to deal with. In addition you can call them and they are more than willing to answer questions. Dale
Gatorman is offline   Reply With Quote
Old 04-03-2016, 02:01 PM   #8
Mike C
Mike C's Avatar
TH200 4R. More overdrive than the TH700 and the one-two gear spread much better. Run it with 3.73 or 4.10. Move crossmember back to TH400 position and use driveshaft as-is.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-03-2016, 02:14 PM   #9
davepl
davepl's Avatar
I would recommend the 200-4R. Properly built, if you're pushing more than stock horsepower (they're likely fine for our stock power levels, I'd bet).
If I recall correctly you don't need to change your driveshaft if you're going Powerglide or TH350 to 200-4R, whereas the 700 may require a change.
When I did mine it was pretty much a bolt-in in place of the TH350. Change the lens on the columns to a 4-speed (overdrive aftermarket) lens, and the detents are in the trans, not the linkage, so that all just works.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-04-2016, 10:20 PM   #10
davischevy
davischevy's Avatar
I am running a 700r4 behind a big block with 3.73 gears in a 71 GMC Longhorn.
Besides what has been mentioned so far, don't forget the little bracket for the TV cable attachment to the carburetor.
I had a ball last week on I-40. The traffic was running 75 and the old GMC was cruising effortlessly. Actually, it wanted to be cut loose from that slow grind.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 04-05-2016, 11:14 AM   #11
Mikem_72
I was running a 350/350 set up and swapped to a 700r4 around 6 months ago and love it. It was pretty simple, I did have to shorten my drive shaft as I was running a short tail TH350. I also had to buy a Lock up kit for the torque converter to run off vacuum. I got the kit from Jegs and also purchased the adapter bracket for my carb from them. I would say that's the most critical thing is getting the geometry and shift points right on the TV cable. I have the parts I used on my build thread.
-Mike
1970 C10 Stepside 350/700r4
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707
Mikem_72 is offline   Reply With Quote
Old 04-05-2016, 11:16 AM   #12
Mikem_72
I didn't have to make any adjustments to the linkage for the indicator.
-Mike
Old 04-05-2016, 12:56 PM   #13
snipescastle2
snipescastle2's Avatar
Talking Re: Swapping out a TH350 for a 700r4 pros/cons?
I'm still working on adjusting mine.the shifter detent plate on the tail end of the column is worn, that makes the shift gates harder to find,and real easy to shift past the gear you want. I also made a custom shifter rod that attaches to both the column lever and the frame bell crank to transmission. So I just need to put the transmission in neutral and adjust the neutral switch and check for proper operation.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
