View Poll Results: dash choices original or new
Original 30 76.92%
NEW please show me your idea 9 23.08%
Voters: 39. You may not vote on this poll
Old 04-02-2016, 01:39 AM   #1
badherb
badherb's Avatar
Talking you decide please
Many of you have come to this problem. And I cant make up my mind. so you get a chance to help me with my truck.
1. Keep original dash instrument cluster shown below.
2. get a new instrument panel now I will show you the one I want after I get a polling done. but use yer imagination, there are a ton out there. and if you want show me you favorite one.
GO!!
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 04-02-2016, 06:30 AM   #2
Greg63
Enjoy your truck
Greg63's Avatar
Re: you decide please
Do away with the one you show (idiot lights) and get an original factory gauges/tach dash.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 04-02-2016, 06:44 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
What Greg63 said. Preserve the past it never goes out of style.
Old 04-02-2016, 06:47 AM   #4
aerotruk63
aerotruk63's Avatar
Old 04-04-2016, 01:42 AM   #5
badherb
badherb's Avatar
modified original like this?????
1960 SWB “Pops”
Old 04-04-2016, 02:38 AM   #6
padresag
your the one that has to live with it. Aerotruk has the original flavour which looks good and is functional. after that spent money to your hearts content
ron
padresag is offline   Reply With Quote
Old 04-04-2016, 04:37 AM   #7
BigDan3131
BigDan3131's Avatar
The Aerotruk deluxe dash is fine in fact it preserves the truck. But it depends on what your goals are, do you need the gauges to be spot on if your running more than a stock engine? Do you want a modern engine with gauges to match?
Link to performance style: http://www.boeseengineering.com/Shop...o-meter-gauges
Link to modern style: http://www.dakotadigital.com/index.c...rod/prd774.htm
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 04-04-2016, 05:39 AM   #8
1strong63
1strong63's Avatar
if it works or needs minor fix then keep it.
1strong63 is offline   Reply With Quote
Old 04-04-2016, 10:32 AM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
My vote - http://www.dakotadigital.com/index.c...rod/prd774.htm
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-04-2016, 02:06 PM   #10
1strong63
1strong63's Avatar
x2
Old 04-04-2016, 03:06 PM   #11
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I can't vote because I have No idea what the rest of your truck looks like. lol My truck is gonna have a Fairly stock appearance, but alot of unique things added. I've decided to go with this style cluster as it best suits my taste.
http://i.ebayimg.com/images/g/vtYAAO...nZ/s-l1600.jpg
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-04-2016, 04:20 PM   #12
vin63
It's Better With Nitro
vin63's Avatar
If you're willing to do the fabrication, wiring, etc., then you can modify the original. Otherwise, going with a modern version from Dakota Digital, and others would be my vote.
Back when I modified mine, there wasn't much in the way of options. Here is what I did with my instrument cluster, using left over gauges, scrap Lexan for a lens, sheet aluminum, and tasking my friend who runs a vinyl lettering and sign business to cut out the numbers and hash marks for me in reverse.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-04-2016, 04:56 PM   #13
badherb
badherb's Avatar
Vin63 wow I like it
1960 SWB “Pops”
Old 04-04-2016, 06:12 PM   #14
aerotruk63
aerotruk63's Avatar
You were able to preserve some of the uniqueness of an original yet modernize it for your application. I like that.
Old 04-04-2016, 06:22 PM   #15
The Rocknrod
Moderator
The Rocknrod's Avatar
Here is a thread with a really nice gauge panel: http://67-72chevytrucks.com/vboard/s...d.php?t=604093
Also see post 11 in that thread.
Old 04-04-2016, 10:49 PM   #16
allchevy58
allchevy58's Avatar
What Greg63 said.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 04-19-2016, 05:05 PM   #17
badherb
badherb's Avatar
Thank you for the help everyone I have decided to save the cash and go with the older cooler one I have. I don't have the gauges that sucks but I don't have a super built motor and I will be adding gauges on a separate mounting. I'm thinking about making a console and adding gauges to it. I will post in my build thread the results on that mod.
1960 SWB “Pops”
