Old 04-02-2016, 06:51 PM   #1
Tcwivwallace
Lights are Fixed (Kind of) and Now it Doesn't Start..
Hey everyone,
I have good news and bad news. Good news is I got power to the back lights(running lights). It turns out it was a faulty headlight switch. Anyhow, next is to the get the brake lights and flashers working, which I believe is the turn signal switch.
Anyhow, the bad news. As my father and I were testing wires to the back lights last week, the truck died. We thought nothing of it and continued testing lights and eventually fixed them. Anyhow, when we went to start it back up, click. From then on, there was nothing but clicks. So, I went outside everyday to do body work and I tried starting it. One day, it started to turn over, but I didn't fire it up only because it 7AM and I didn't want to wake all the people in my dorm. Anyhow, my father and I decided that the issue was the starter. So, just today, I purchased a new starter and solenoid. As soon as it was all hooked back up, just clicks. After the clicking, I checked the battery voltage. I found 11V. So, I went out and bought a brand new battery. Still, just clicks. I need some help with this issue. So, total, it has a brand new battery and a new starter. If anyone has any ideas or suggestions, all help is appreciated.
http://67-72chevytrucks.com/vboard/s...d.php?t=696727
1972 GMC C1500 5.7L 350 2WD
Ted
Tcwivwallace is offline   Reply With Quote
Old 04-03-2016, 01:34 AM   #2
El Dorado Jim
Re: Lights are Fixed (Kind of) and Now it Doesn't Start..
check your ground cable connection,where it connects to the frame and or engine
El Dorado Jim is offline   Reply With Quote
Old 04-03-2016, 02:07 AM   #3
66clow
66clow's Avatar
Having a similar issue have not checked it yet but I think my issue is needing to shime the starter possibly. My solenoid sticking.
66clow is offline   Reply With Quote
Old 04-03-2016, 09:19 AM   #4
jjzepplin
jjzepplin's Avatar
Charge your battery
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-03-2016, 10:43 AM   #5
snipescastle2
snipescastle2's Avatar
Talking Re: Lights are Fixed (Kind of) and Now it Doesn't Start..
I agree with the ground theory. If you turn on your headlights and then turn the key over and the lights dim, most likely a ground issue. One other thing to check, there are two types of ring gears, one has 58 teeth and other has 60+ (can't remember exactly) if the nose of the starter isn't matched for the correct flywheel/flexplate, the starter might be hung up on the ring gear. can you jumper the terminals on the solenoid with a screw driver and see if it turns over there? just a suggestion, but be careful with a screw driver when jumpering the solenoid, you can "Arc Weld" the blade to your manifold/headers if you accidently ground the hot cable with the screw driver!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 04-03-2016, 12:08 PM   #6
cdowns
cdowns's Avatar
remove the two battery cables and clean all 4ends to bright and shiney then have somebody install them and tighten them up
Old 04-03-2016, 12:19 PM   #7
68 Chevyota
Ben
x2!!
I would rather have a free bottle in front of me than a prefrontal lobotomy!!!!
68 Chevyota is offline   Reply With Quote
