04-03-2016, 10:07 AM | #1 |
moving steering box confused
ok i moved my steering box 1 3/4 in 50 chev ive read a thousand posts how people say there using existing mounting location in cab im really confused at that my column is at least a 1 1/2 off what am i missing
04-03-2016, 01:48 PM | #2 |
Re: moving steering box confused
Not a thing. that is normal. I think we moved the bracket over or rigged a different bracket when we did mine in the mid 70's. I know I didn't modify the dash to do it. I'm not exactly what we used for the clamp to clamp the column to the dash. My buddy in Waco Tx that helped me do it was a mad genius when it came to figuring out how to make things work and do it simply. He may have used a muffler clamp rather than the regular clamp if we used a clamp at all. We did the swap in a weekend and maybe a night or two after work in his father in law's shop where we both worked at the time.
I was running a 59 Corvette wheel (that I wish I still had) at the time that was a couple of inches smaller than the stock wheel.
04-03-2016, 03:11 PM | #3 |
I have only did it once, years ago. When I did I used a piece of a spare frame and welded it right there at the same spot on the frame to bring the box out the distance of the frame..1 1/2"? I trimmed the hole in the firewall to match and as I remember I don't think I moved it at the dash at all the column was at a slight angle.....as I remember. But the recess in the dash for the column is off to the right compared to the gauges.
See how the hole is closer to the speedometer of that. So you could cut that, move it to the left and put it where it is suppose to be to match the moved over box! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
04-03-2016, 04:01 PM | #4 |
thanks guys just need a different opinion besides me staring at it ha
04-03-2016, 05:27 PM | #5 |
I moved mine years a go. box is moved 1.5" to the left, firewall is trimmed to clear column, dash bracket is the factory stock one in the original position. the wheel is moved slightly right but after 40+ years of driving it this way, I don't notice the difference
04-03-2016, 06:50 PM | #6 |
Too late since you already moved it, but the 60's and 70's Ford pickups had the engine offset 2" to the right. When I put a 350 in my 54 GMC ,I offset it the same--no need to move the steering gear. I used rams horn manifolds and it worked perfectly. Just a hint to help someone else. Joe
04-04-2016, 07:48 AM | #7 |
As an interesting note the 47-53 larger trucks use the same dash and use an off-set (to the left) column mounting bracket. It puts the column in the center of the gauges and drops it a little. Mine has one. Not the best shot. the right leg is hidden by the wheel.
Rob
My '47 C.O.E build |
