Old 04-03-2016, 12:57 PM   #1
95chev-w/t-guy
95chev-w/t-guy's Avatar
1984 C10 DJM Drop Spindles HELP
I'm having clearance issues with my DJM drop spindles, but not with the wheels, with the bump stop. It seems like it's making contact early and not letting the spindle cut far enough, any help/advice from someone that's used drop spindles before?
1984 c10 - my forever truck
1991 GMC R2500 6.2 Diesel
1995 GMC K2500 LQ4 swap coming soon
2002 2500hd cclb LQ4/NV4500 2wd - parted out
1998 c1500 - sold for parts
1995 c1500 - sold to my brother, then sold again but still going
95chev-w/t-guy is offline   Reply With Quote
Old 04-03-2016, 02:31 PM   #2
PunishedC10
Re: 1984 C10 DJM Drop Spindles HELP
I will have to look at mine later today and see. I didn't have this problem with mine on my '85.
PunishedC10 is offline   Reply With Quote
Old 04-03-2016, 05:26 PM   #3
bbbc10
Diggin The SquareLife
its not your spindles its that bracket the spindle is hitting cut it off and u should be good to go....my control arms don't have those little brackets.
bbbc10 is offline   Reply With Quote
Old 04-03-2016, 06:16 PM   #4
cheap
That's the steering stop, it prevents the steering from moving the wheel too far. Though i remember my CPP spindles having a much shorter steering stop on the control arm side, you could clearance them to provide a shorter turning radius
cheap is offline   Reply With Quote
Old 04-03-2016, 06:46 PM   #5
bbbc10
Well the set on my truck an the extra pair i have only has the bump stops on the arms not the little bracket his spindle is hitting.
Old 04-05-2016, 08:12 PM   #6
95chev-w/t-guy
I think I'm going to shave a little off the spindle and see if it's enough. I've also realized that once there's weight on the front end, there is a little more clearance but it still doesn't look like enough.
