Old 04-03-2016, 01:01 PM   #1
PIG-TECH
PIG-TECH's Avatar
working on my heater
i could use a pic or two of your vacuum canister. i just notice my is gone and will need to buy a new one, probably just get a after market one but not sure what to get. so what has been working for you guys? my truck is a 72' C20
PIG-TECH is offline   Reply With Quote
Old 04-03-2016, 02:39 PM   #2
Tumbleweed1C4
Tumbleweed1C4's Avatar
Re: working on my heater
Mine was missing too, ended up just buying one from The Truck and Car Shop in Orange CA, for 20-something bucks, for no other reason than I was buying some other stuff from them. It is like a ball shape, I think originally they were more of a barrel shape, but the GM replacement was the ball like the car version. Works, bolted right on. Any of the places that carry replacement parts for our trucks will have them.
Sleep safe in your beds because rough men stand ready in the night to visit violence on those who would do you harm
72 K5 Blazer
72 K10 SWB (in pieces under slow construction!)
72 K20
Tumbleweed1C4 is offline   Reply With Quote
Old 04-03-2016, 02:40 PM   #3
Tumbleweed1C4
But, looks like your bracket is missing
72 K5 Blazer
72 K20
Old 04-04-2016, 12:09 AM   #4
FirstOwner69
FirstOwner69's Avatar
Attachment 1517980
I think the bracket is a 4WD thing only. The 2WD trucks did not use the bracket.
Regarding the vacuum canister, I've seen both the coffee can metal version (as original on my 69) and the plastic ball on these trucks. The ball type appears to have been used exclusively during the later years of this generation trucks. From pictures posted here, I'd say the ball canister is most common overall.
FirstOwner69 is offline   Reply With Quote
Old 04-05-2016, 12:12 AM   #5
Mmorgan32
Mmorgan32's Avatar
My truck is missing it as well. What does it do? Mines an ac cab it's missing everything. My heater works but hot air always blows in. Sorry if I just hijacked the thread
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 04-05-2016, 12:36 AM   #6
PIG-TECH
PIG-TECH's Avatar
Lol . no problem all threads are here for the taking. The Reservoir canister is for opening your side vents and I'm not sure what else. I just took all my duct work apart and found a massive mouse nest.
Old 04-05-2016, 12:40 AM   #7
Mmorgan32
Mmorgan32's Avatar
My heater works great. All vents work. But it just always has hot air blowing in its weird and very annoying in the summer
Old 04-05-2016, 12:58 AM   #8
Curtb1971
Curtb1971's Avatar
Had the same problem on an AC truck I used to have. On the factory AC trucks there is a vacuum water valve on the supply heater hose to the heater core off the water pump. Since my ac was non working and partially disassembled I put a manual 1/4 turn valve in the place of the vacuum valve. In the summer close the valve, in the winter open it up. I was a quick fix, but sure helped in the summer at 100+
Curtb1971 is offline   Reply With Quote
Old 04-05-2016, 04:59 AM   #9
hdff
hdff's Avatar
Here's a pic of mine that I just got finished refurbing. The vac ball has the attaching bracket attached to it and bolts to the evap case. I put a new vac water valve into the water line and still get hot air. I installed a valve in the hose and will close off the water int the summer to the heater core
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
