Old 04-03-2016, 03:11 PM   #1
SSpeed66
SSpeed66's Avatar
60-62 Rearend Measurement Needed
I have a 66 rearend I'm going to use under my 61. I need the measurement centre to centre of the trailing arm mount pads, as it is different from my 66 rear. TIA
Living The Canadian Dream in British Columbia
SSpeed66 is offline   Reply With Quote
Old 04-05-2016, 04:13 PM   #2
SSpeed66
SSpeed66's Avatar
Re: 60-62 Rearend Measurement Needed
Anyone ??
Old 04-05-2016, 04:52 PM   #3
Bullett
Well, I just slid under my 62' with a tape measure and am not really sure exactly where to measure from, to get you exactly what you are looking for.
Bullett is offline   Reply With Quote
Old 04-05-2016, 05:27 PM   #4
SSpeed66
SSpeed66's Avatar
I doubt it is possible to get that measurement with the rear attached to the trailing arms, but thanks anyway !
Old 04-05-2016, 07:27 PM   #5
slepysal
slepysal's Avatar
So you need a measurement on the 66 rear end? When I did my swap I used my original rear end as a guide, ground off the saddles off of the new one ( a 1967 in my case ) and welded on new ones.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-05-2016, 09:03 PM   #6
HumphreyMurdoch
HumphreyMurdoch's Avatar
I have the original rear end housing from my '62 hanging out. I'll do my best to get the measurements you need. If I remember, the u-bolt holes are pretty rusted and wobbled out. So I'm not sure how accurate the measurement will be.
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
