Old 04-03-2016, 07:48 PM   #1
crazyjim
crazyjim's Avatar
Need Help
I have a 1998 chevy has all lights working on passenger side but driver side rear has only tail light no brake or blinker what could be wrong ? all bulbs are good.
crazyjim is offline   Reply With Quote
Old 04-03-2016, 08:09 PM   #2
spinne1
Re: Need Help
The bulb holder could have a bad connection. You can get those at any auto parts store and solder in the new one. Or, you could have bad wiring to that side for those circuits. It is likely one or the other.
spinne1 is offline   Reply With Quote
Old 04-03-2016, 08:10 PM   #3
54 jimmy
54 jimmy's Avatar
Re: Need Help
check for power at the socket with a test light. also check for power at the connector of the rear harness if it is a truck. sub or ho you will have to trace the wire to find the break or cut. good luck.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 04-05-2016, 05:55 AM   #4
Rod_Lei
Re: Need Help
Possible circuit board failure, fairly common on these trucks.
Rod_Lei is offline   Reply With Quote
