72 C20 Cheyenne super Restoration
Finally found the exact truck I wanted that was close to home. Factory 402 3/4 ton I have many questions this will get a restoration but first need date correct 402. Truck has tilt but not on Spid sheet? Also door panels don't appear correct for a super plus some idiot cut hole in both for speakers
Re: 72 C20 Cheyenne super Restoration
Pic
Pic 3
Nice find. I'm working on a 72 c20 Cheyenne super myself. I think you will have a really nice rig when you get done.
'72 chevy C20 Cheyenne Super |
Front
Yea the super door panels have the wood grain insert not the scroll pattern. You can buy aftermarkets or look on eBay
Interior
Dumb dumb
Rear
Since it lists parchment on Spid would it be white door panels to match headliner and visors in the truck or blue door panels? I've seen both with wood inserts
Since there are a number of detail differences, from original, I'd suggest verifying the SPID matches the door plate with original rivets and the last eight of the VIN match the frame numbers.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#13 |
All numbers match and clean title
#14 |
![]() Join Date: Sep 2007
Too bad you don't live closer to me, I have the correct '72 402 you need for your truck, complete re-builder. Some thing to think about!!
1971 Cheyenne Super C-20 402 4 speed 1970 El Camino L-48 350 1999 Chevy Z-71 Extended Cab 4x4 2000 Tahoe Z-71 2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator 1970 Chevelle, Malibu Sport Coupe 2007 Harley-Davidson FLHX Street Glide |
#15 |
Lurky lurky
The speaker holes are unfortunate... the panels are Cheyenne Super equipment though, the trim around where the woodgrain should be is a tell tale sign of that. The lower trim models don't have the ring. It does look like the real deal, unfortunate that is has been messed with but should make for a great project!
#16 |
Someone probably added the tilt later. My K10 Super has tilt and tach, but neither are on the SPID. I can tell the tach is newer because the orange needle isn't as faded as the other gauges...
Your new truck looks a lot like mine, same dark blue/white combo... congrats and have fun!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
