Old 04-04-2016, 11:54 AM   #1
j_cst_10
j_cst_10's Avatar
C20 front coils
I thought I would put up the outcome of trying a different set of front coils in my 72 C20. I had found them on an old thread on here but never saw any pictures of the finished result so I crossed my fingers and ordered them.
The truck sits really nice (hard to see from the picture angle but it is a little nose down still, which is where I wanted it. Pretty much level with a very slight forward rake).
The truck has stock rear leaf springs and a 1" body lift (to clear the drivetrain). The truck rides and handles a lot better than the factory front coils. Firm but stable and is probably smoother than the factory coils.
The springs are Moog 6454 and were around $80 shipped from rock auto.
j_cst_10 is offline   Reply With Quote
Old 04-04-2016, 02:54 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: C20 front coils
Good info, thanks for the heads up! I just dropped a big block in a C-10 that had a 350 small block originally. I cut a 1/2 coil off the factory coils to get another inch drop when I installed the drop spindles. Now the the front end seems bouncy with the added weight of the big block. I'm thinking 3/4 ton front coils and if needed, 1/2 coil sawed off...We'll see...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-04-2016, 05:04 PM   #3
j_cst_10
j_cst_10's Avatar
Re: C20 front coils
If you want a lowered look with a big block buy the Hotchkiss ones. At $200 they are pricey but we're in my other truck and drove great.
The springs pictured will probably be pretty stiff if you start sawing coils out of it.
