HOOD - COWL Gap ? How to?
Re: HOOD - COWL Gap ? How to?
Can't you just loosen the hood hinges and (carefully) slide it back towards the windshield a bit? Normally there's room for adjustment.
Of course that might throw your rad support and latch out, but then they're wrong and need to be fixed. You always start with what you can't move (like the windshield, and the cowl up against it) and then move on to the things that can move...
If the gap was fine before and your confident the hinges are real close to the same location as before then you may want to give the hinges a few shots of some penetrating oil as they could be binding up.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() ![]() Join Date: Feb 2009
What the others have said. If it's an alignment issue, you might notice something between the hood and grille.
Here are some of the notes I took when I removed my hood recently. Items in red font seem most important in your case. You'll see "hood brace". This is the part where the hood mounts to the hinges. There may be a more better description....... Hood to Hinges Each hinge is mounted to the hood with two 9/16" head tapered screws with integrated washers. Incidental: The two “screws” on the fronts weren't tapered. The front edge of each hinge was flush with the edge of the flat surface on the hood brace. Reference the 1/2" holes on the hood brace. The outer edge of the nearest hole straight to the edge of the hinge was 17". This applies to both sides. General Alignment of the Hood: There was 3/10" separation on the RH side, and 2/10" separation on LH side, which is measured from the top corners of the cowl and hood. The alignment on the rear portion of the hood and fender is too close on the RH side, and scratches the paint. Note this is near the rear rubber bumper that inserts into the fender. My first instinct is shim the RH fender, but the fender is flush with the door. However, the LH fender is approx. 1/10" an inch deeper than the LH door. If the LH fender is shimmed, that may solve the problem on the RH side, but could contribute to new problems, because the LH hood, cowl and fender line up nicely. Find out if the top rear fender should be flush with the door. Only input so far is I should feel lucky it's as straight as it is. Images captured.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-04-2016 at 08:23 PM. |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Them seals bind the hood when they're new. Squirt some WD-40 all along the new seal. You may have the seal pushed in towards the cab a bit to far as well. If the WD-40 trick dont work right away, loosen the screws and pull the seal towards the motor a bit to allow it to fold more easily. If that dont work, then it may be time for new(er) and tighter hinges...~Ghostrider~
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American"
Thanks guys
I use WD-40 for lots of things. Depending on the source, it's hit and miss whether or not it should be used on rubber. Personally, I tend to avoid it, though in this case I'm sure you're fine using it....... Lots of info. on the web concerning correct lubes for rubber.....Good luck! http://www.bobistheoilguy.com/forums...bber_Lubricant
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-05-2016 at 01:16 AM. |
| Bookmarks |
