![]() Join Date: Feb 2004
1985 short, step, 4X4, 350, SM465...will it take a big block w/headers?
I have this big block, 468/450HP W/headers sitting in the shop, waiting for something to go in. I would really like to put it in this cool shortbed I bought. Since I'm to busy (lazy) to do a build of any sort I wonder if just the engine swap would be straight forward and easy
Comments,opinions and critique welcome |
Re: 1985 short, step, 4X4, 350, SM465...will it take a big block w/headers?
I'm not a mechanic or an automotive professional of any type so I would recomend finding someone that has done it. I think it would be pretty straight forward though. You might have to uprade your radiator, fan shroud, maybe your clutch and flywheel and possibly the motor towers "67-72 has a difference but I'm not sure about 73-87". I know motor mounts can interchange but the height difference of the towers may effect the way your fan fits in the shroud. Your on the right track with doing research!!! Hope it helps
1971 Chevy shortbox 4x4 made in Canada |
Well, If you weren't so "Busy" you could do a search on the forum and find a bunch of builds that converted from small block to big block.
![]() From what I have read it is pretty straight forward. I myself haven't done it so I can't offer any truly constructive advice. I really replied mostly so I could bust your balls about being lazy....oops, I mean busy.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#4 | |
No apologies are necessary. I was just giving you a hard time because you opened the door with your busy (lazy) comment. I agree that asking a question of the group is much quicker than searching and reading through dozens of threads to answer your question. I guess the smiley didn’t convey my attempt at humor.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 Last edited by daddyjeep; 04-05-2016 at 01:48 PM. Reason: Spelling |
Well, honestly, I don't know what kind of vehicle you could buy that has more room under the hood than a C10 squarebody. A 1972 Eldorado, maybe?
At the body shop.
The trans will take it, the headers maybe an issue. Clearing the Z bar
" That didnt make it any newer " " Dont antique the equipment " |
a big block swap is easy. I kept the factory exhaust manifolds on mine.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
| Bookmarks |
