Wiper Motor Nightmare - HELLLP!!! - '55 3100 2nd Series
I am in dire need of some help. Unbelievably, it appears that a PO has cut out the mounting for my wiper motor and replaced it with an unknown mount (and he/she did a really nice job too!):
If someone has a picture of a '55 3100 2nd series wiper mounting area I could sure use a look at it. If someone recognizes this "new and improved" mounting scheme I could use that piece of info too. Also shown here is the bracket I have and the motor I have. Are these '55 parts? Also, if someone has a donor truck and wants to sell me this motor mounting area, I'm probably going to be in the market after I figure out what's really going on. Thanks,
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
Re: Wiper Motor Nightmare - HELLLP!!! - '55 3100 2nd Series
Here is the motor in my 59. It came out of a 58/59 GMC. Motor looks the same as the one you show. Here is also a photo of the stock bracket, it is factory welded in. Maybe in 55-57 it was bolted??
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#3 | |
I compounded my problem by cutting out most of what you call the "factory support". I did that to make room for my center channel speakers. When I did that I thought the brace was just there for dash support, so I cut most of it out. I thought the captive nuts in it were to support the radio (which I am mounting in the headliner area). I didn't think about the wiper motor because the other two brackets were there, as shown in my picture. I mean, how many brackets do you need to mount a stinkin' motor? (Apparently one more than I have...) When I cut the support out I did leave one captive nut, so I can see where the motor needs to be located, left to right. Unfortunately, if I install the motor in its original position the arms will hit my speakers. I'll have to drop the motor down a little over inch, but that shouldn't be the end of the world. At worst I'll have to lengthen the arms a little bit. Thanks again, Orrie! If anyone else has any input, I'm interested.
dropping the window motor 1 inch will require you to re-engineer the wiper linkage. This may cause some performance issues with the operation of your wipers. I would vote to move the speaker as opposed to modifying the wiper set up.
Hey, you asked for input. :-P
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1 |
"Customize" it....
My Build: 57 Chevy Pro-Street |
#6 | |
Amen, ptc...amen!
Here are the details on the fix. Here's the riser, mounted to the wiper motor (or should I call it the "lowerer"?). Note that it has a through hole and a pin.
The riser bolts into the one factory threaded hole that remains, and the pin goes into the locating hole to keep the assembly from spinning. I tried to take pictures similar to Orrie G's, so here they are: When running, the passenger arm is closest to hitting, and misses the speaker by an 1/8". Now, back to the body work...
Nice fix. Before I found a stock motor in the 80's I made a bracket to use a 62 truck wiper motor and modified the arms (length) to make it work. No pics of that.
#10 | |
BTW, apologies to all due to this being a redundant post. This topic is also covered in my build thread. I had put it there first, then realized it wouldn't get the responses it gets here. Why would anyone want to see my other mistakes? ![]()
