04-05-2016, 08:11 PM | #1 |
Anyone running a boyd welding fuel tank?
Hey guys. Thinking about running a boyd welding tank in my 55 Second Series. I have C4 rear suspension and curious if it will clear the rear sway bar. Would really love to see pictures of one installed in one of our trucks to see how it fits.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
04-05-2016, 10:30 PM | #2 |
Re: Anyone running a boyd welding fuel tank?
Never heard of boyd welding if you install take pictures and post them.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
04-05-2016, 11:10 PM | #3 |
Here you go rude dude. They make the best looking tank in my opinion. Just curious how it would fit around my sway bar.
http://www.fueltankparts.com/replace...5-59-c-10.html
04-06-2016, 12:21 AM | #4 | |
Yes, doing it that way WOULD make it harder to drop if you ever needed to...but then again, how often do you ever need to remove your gas tank?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
04-07-2016, 01:28 PM | #5 |
design to work on it, i'd hate to pull the bed to remove the fuel tank
i run a similar no limit engineering tank on truk with an in tank pump coming home to detroit from dallas, tx in nashville, tn i had the hose to the pump fail i dropped the tank, fixed the hose and was back on the road a year later the pump failed near the house, i've dropped my tank 4x since getting it on the road
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-07-2016, 08:12 PM | #6 |
I have a simular tank and it goes under the cross brace behind the rearend. You would have to take it out to mount it above the frame.
04-08-2016, 09:25 AM | #7 |
This one is less in price and works good in a TF Truck.
http://www.tanksinc.com/index.cfm/pa...rod/prd502.htm
04-08-2016, 12:34 PM | #8 |
C4 in a 58 owner here also,and have not pulled the trigger on a tank yet also!
Would like to see this Boyd Tank installed as well if there is one? Allen |
04-08-2016, 07:02 PM | #9 | |
It looks like that Mustang tank mounts on top of the frame top flange, doesn't it? I like the price and that its 22 gallons!
04-08-2016, 08:36 PM | #10 |
I used one in my 48 truck and it worked well. This one is revised and has a more user friendly fuel fill.
04-08-2016, 09:23 PM | #11 |
I cant mount on the top rail due to the C4 sway bar being there.
04-08-2016, 09:38 PM | #12 |
Maybe it will mount on bottom of bottom
flange? I'd use some 1/8"X1-1/4" strap under the bolts though if I did that just to keep the tank sheet metal from tearing through over time. Just not sure if if would hang too low though? Excellent price I think.
04-09-2016, 01:01 AM | #13 |
The price is great on the mustang tank. Here is a picture of my frame and how the C4 sway bar mounts. I have already removed the rear cross member so, I can bolt it in wherever when I mount the tank.
04-09-2016, 08:00 AM | #14 |
That is a great looking chassis Chief! In case you didn't notice, Tanks lists the LxWxD dimensions for all their tanks for you to compare and measure for fit. Unfortunately they don't have it all on one spreadsheet.
04-09-2016, 11:42 AM | #15 |
Chief, Yes your frame looks nice. Maybe I missed it: Is it powder coated or painted? If painted what did you use?
04-09-2016, 03:42 PM | #16 |
I'll get the measurements and see if it will clear. The frame is powder coated. I have a build thread going on as well.
06-06-2016, 08:09 PM | #17 |
As promised, here are some pictures. I have to say after being let down time and time again by aftermarket quality, the boyd tank really impressed me. I would say it was well worth the $448. Came with everything pictured minus the bolts to mount it. I used some nice polished stainless bolts and toolbox drawer liner between the fuel tank and frame to act as an anti-squeak. The welds and finish are spectacular and I was able to clear the sway bar. Doesn't hang to low in my opinion and the best part is its made right here in the Good Ole USA, down in Florida.
06-06-2016, 08:11 PM | #18 |
More pictures...
