Old 04-05-2016, 10:28 PM   #1
prin
prin's Avatar
led turn signal mirrors
I just bought these for my 72. But I didn't get any directions. So, how are yall wiring these things up???
prin is offline   Reply With Quote
Old 04-09-2016, 02:06 PM   #2
prin
prin's Avatar
Re: led turn signal mirrors
So no one has done these???
Old 04-09-2016, 04:49 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: led turn signal mirrors
Should be simple enough. Cut your turn signle wire in the truck now and run it to the mirror then from mirror back to other end that you cut.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-09-2016, 09:45 PM   #4
swamp rat
swamp rat's Avatar
These???? It might help you if you would post a link to the product in question.
Less than 5 minutes using the search feature on this forum, i found this, if this is the same product.
http://67-72chevytrucks.com/vboard/s...ht=LED+Mirrors
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-10-2016, 08:41 AM   #5
Andy4639
Old member
Andy4639's Avatar
I found this also off a e bay add for them.
•Easy Hookup, Just Route Wire through Door Jamb and Connect to Front Turn Signal Wires Under Dash Near Steering Column
•Correct for 1970-72, But Can be Used to Update 1967-69 Trucks
Old 04-10-2016, 10:53 PM   #6
prin
prin's Avatar
Thanks a lot fellers!
