Old 04-06-2016, 12:35 AM   #1
Softpatch
Softpatch's Avatar
Rearend and trans lube change Viking 59
Just checking a few things off my list to getting roadworthy.....
Today I open rear end and change fluids on both rear end a trans
with 75,000 + miles and been sitting for yrs..
I was happy to see the rear end oil/lube full and no suprises
BEFORE
cleaned painted cover
And made a gasket
The trans fluid change
The rear took 2.5 gal
the Trans was just under 1 gal
.....................................Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 04-06-2016, 04:56 PM   #2
mphudak
Re: Rearend and trans lube change Viking 59
OH MY! Those are some serious bearing caps, makes one of my old Dana 60's look inadequate. I couldn't imagine how badly that trans or diff oil smelled.
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
Old 04-07-2016, 01:15 PM   #3
_Ogre
_Ogre's Avatar
that is a serious stack o springs on that viking
is that a posi rearend? looks like room for the clutch pack
shop air compressor timer
Old 04-07-2016, 03:05 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
I'm surprised you didn't have a bunch of flake rust inside after all those years, That look really clean
dwcsr is offline   Reply With Quote
Old 04-07-2016, 09:35 PM   #5
Softpatch
Softpatch's Avatar
I wish and wonder why it wasn't but it's a
non posi...
without the Duels I almost got stuck
surprising no rust not even the inside of the tin cover with no paint on it no rust.? and the rear end oil was full and did not smell that bad
Only thing I can figure is the gear oil did it's job by coating everything inside that big ol rear and preserved it
funny everthing above ground rusty as all get out...
bellow ground no rust go figure.?
As found 06-13-2014
Old 04-07-2016, 10:57 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
I don't know of any two speed axles that were POSI back then. it was hard enough getting the planetary reduction gears in the carrier housing let alone a POSI unit
Old 04-08-2016, 03:21 PM   #7
_Ogre
_Ogre's Avatar
doh! now i see the vacuum lines to the rearend
i had a 56 chevy schoolbus/camper that had the vacuum 2 speed, luckily i never had to go into it
Old 04-08-2016, 10:39 PM   #8
Softpatch
Softpatch's Avatar
Today was a good day.!
longest trip to date in the truck
Well did some house cleaning today (wiring) took it out to get fuel
down to 9% in a 30 gal tank.?
to the local propane store (only one) when i got there they were closed no reason probably because it was sunny and friday.?
It was a grueling 6 miles round trip and when I say grueling.
I'm mean I think I bruised a kidney....
The tires felt like there were more square then round it rattle so hard knocked the cap off the battery
it was a tough go I hit 35 in fourth gear so I tried my hand is two speed shifting
I failed miserably .......
Did get the rear to shift twice
I think the magic is
get up to speeds
push in clutch
let the engine idle (to build vacuum) while rolling hard
hit the two speed axle button
let out the clutch give some more fuel and hope for the best
I'm 2 out of 7 tries
I'll have to study that utube video some more
sorry no pictures of truck
but you ol duffers might appreciate a model 77
Old 04-08-2016, 11:27 PM   #9
Softpatch
Softpatch's Avatar
the sticker I tried to remove off the dash before restore mode
I'm so confused.???
