04-06-2016, 09:37 AM | #1 |
Urine Smell in the vents
Hey guys,
While doing my rad flush I had to crank the heat for 10 minutes. Good news is that the heat worked (could be better but it worked). Bad news is a strong urine odor. I know something lived under hood as I found a pile of acorns under battery tray and various locations. My question is What is the best plan of attack, I'm planning on pulling the glove box and looking around in there and also the heater on the firewall and checking in there and cleaning with bleach. Has anyone been down this road before? If so any tips. I won't even mention this one to my wife for fear she would never step foot in the truck Thanks
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ Last edited by old Rusty C10; 04-06-2016 at 07:47 PM. |
04-06-2016, 09:58 AM | #2 |
Re: Piss Smell in the vents
The odor is probably caused by water sitting somewhere -- now or in the recent past. You won't see anything just looking at the heater box. The only way to get inside is to remove it.
If the blower hasn't been run in a while, I'd try driving around with it blowing full blast, and change the airflow from defroster to floor, etc. The smell may go away on its own. If not, maybe a little air freshener sprayed into the cowl vent (while the blower is running) will help. Also, make sure the blower box doesn't leak at where it joins the firewall.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-06-2016, 10:06 AM | #3 | |
04-06-2016, 10:09 AM | #4 |
Mike thanks for the suggestions, I'll check the blower box for leaks. I haven't run the blower since I've had the truck and that is 2.5 years.
I think it's more than just sitting water based on the smell. It would be nice if that was all but I guess I won't know until I start poking around. I did find mouse droppings in the glove box...so I know something had been back there at one point.
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
04-06-2016, 10:11 AM | #5 |
That's what I think...just seeing if anyone had any tips before I get in there and break something.
04-06-2016, 10:37 AM | #6 |
Read some of the forum threads on heater core replacement. Here is one: http://67-72chevytrucks.com/vboard/s...d.php?t=460942
For that matter, consider replacing the heater core while you are at it. It would suck to be there, clean everything up only to have it start leaking once the truck resumes normal usage. Be sure to check the gap between the heater box and the defrost vents. It often needs some tape. |
04-06-2016, 10:51 AM | #7 |
Yeah, if there are droppings or a dead mouse in the box, that's definitely not gonna get fixed w/o taking things apart. After my post above, I also thought about the heater core having who-knows-what clinging to it.
Speaking of heater core replacement, see my experience here (with a non-AC heater): http://67-72chevytrucks.com/vboard/s...d.php?t=696591
04-06-2016, 10:57 AM | #8 |
Awesome thanks guy, I searched piss smell it didn't come up with anything. This will help for sure.
I pulled the glove box and looked inside and it looks like a project to get it apart. I was adjusting the heater vent and I could hear some stuff scraping inside. Parrot your right - I looked at that gap and thought "that doesn't look too efficient" I'll close that gap while I'm in there. Mike I'll read over your post now
04-06-2016, 11:06 AM | #9 |
Sounds like you have a mouse nest in your vent tubing. It's pretty easy to remove all the tubing behind and under the dash. When I had my dash pad off to re-dye and put all new parts on the dash, I removed all the vent tubing and actually cleaned them out before re-installing. Mine were just full of dust and a few leaves. But I would say, you have a mouse that has a made a nest somewhere in all the tubing.
04-06-2016, 11:11 AM | #10 |
I don't have AC so that's supposed to make things easier.
Here's a vid I just found https://www.youtube.com/watch?v=VHXaMDByBUI After watching the vid it doesn't look too bad. Just called NAPA and it's only 68 bucks for a replacement, makes sense while I'm in there. Guys I appreciated the guidance on this one. I report back with some picts when I get to it.
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ Last edited by Shugalou; 04-06-2016 at 11:22 AM. |
04-06-2016, 11:26 AM | #11 | |
04-06-2016, 11:55 AM | #12 |
Moderator
Pull the cowl covers and suck any nesting material and urine out with a shop vac. Vent the vac away from yourself with a chunk of shop vac hose. Wear a mask and don't breathe it. Hanta virus is nasty stuff.
Rinse the cowl out with water and Clorox or pet urine enzyme smell killer. Be sure to rinse lots of water through there. Clorox is corrosive. I'd be tempted to pull the heater box and the blower housing and clean it with Clorox. Rodent urine is a very strong lingering smell. If you have a good sense of smell I'd replace the plastic heater box altogether. It may not smell when it's cold outdoors but once it gets hot out it'll stink.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-06-2016 at 12:03 PM. |
04-06-2016, 12:10 PM | #13 | |
http://www.oreillyauto.com/site/c/de...rd=heater+core And it fills the gaps completely.
04-06-2016, 05:08 PM | #14 |
Hatzie,
Thanks for the tips - where will the water and Clorox run out from the cowl under the brake booster? I don't want it filling up the cab. Yes I do have a good sense of smell so I may consider replacing unit if I can find one and if it's cheap enough...Maybe I should spray it with WD I love the smell of that stuff. Mike, yeah us Canadians don't have the options that you guys have for parts. I was able to find one for 56 bucks so hopefully that does the job. I pick it up in an hour
04-06-2016, 05:41 PM | #15 |
One tip I haven't seen. Mouse urine glows a dull greenish yellow (like it was radioactive) under black light. Easiest way to tell where you need to clean, and also where they were getting in. Mice don't have bladders, so they leak urine constantly, and there will be a trail.
Rich Weyand 1978 K10 RCSB DD. |
04-06-2016, 08:06 PM | #16 |
Re: Urine Smell in the vents
Rich great tip - makes me wish I had black lights installed for mood lighting and tracking down mouse piss.
I've started at it and only one bolt is holding it to the firewall the other two had plugs jammed in and sealant all around. There was a pad with sealant too (maybe the pict will show it). Is the Pad a stock item or something this guy put on to close the gaps...ATTACH]1519521[/ATTACH] It looks like it's in crooked as there is a lot of space around the drivers side of the pipes. I'll put a pict of the crookedness shortly.[
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ Last edited by Shugalou; 04-06-2016 at 08:12 PM. |
04-06-2016, 08:17 PM | #17 |
Everyones needs a black light for mouse piss tracking
04-06-2016, 08:40 PM | #18 |
Just take out the blower motor, most time you will see it packed @ the heater core and the blower motor, if not there pass vent area to the heater core.
kill the vermin ( keep your vent closed when parked long times ). THEY GET IN THE COWL VENT AREA TO THE HEATER.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
04-06-2016, 10:54 PM | #19 |
Pontiac I haven't had a chance to check the blower motor area but that will be next after I restore this mess.
First the crooked pipes coming out - the one screw was bent all funny - you'll see in another pict hopefully. So I follow the steps in the guys vid and he was bang on - came out much easier than expected Looking pretty good - maybe I shouldn't bought that heater core after all Pull off the lid to check inside - Honey I'm home So my plan is clean it all up - bleach and repaint the plastics with a krylon for plastic to seal in any smells if they remain. And for the metal Wire wheel, bleach and repaint. I can say now I know why it didn't feel like much heat was coming from the vents and why it smelt so bad.
04-11-2016, 08:58 AM | #20 |
So I took everything apart bleached plastic a few times, cleaned with simply green a few times,scuff sanded and sprayed with a plastic friendly spray paint.
I disassembled all the doors and soaked them for 24hrs in vinegar to clean off the rust, then I spray with a rust inhibitor and some high heat paint that I had kicking around. While I was in there I put in some screens as an "upgrade" Before I put it back in I'm restoring the passenger kick panel vent. Fresh air soon, this has been a fun one so far - Thanks guys for the help
04-11-2016, 10:08 AM | #21 |
Nice.
Take the caps off those hose nozzles before you install. They're a bastard to get off once it's installed.
04-11-2016, 11:06 AM | #22 |
Hi Rich thanks for the tip I haven't seen how hard they are to pop off I just assumed they would slip right off I'll check it out...If they are supper tight I'll remove and tape up while installing.
04-11-2016, 10:37 PM | #23 |
Hi Rich I get the joke now - nice one.
Before I reassemble I am restoring the passenger kick vent with new gaskets and paint. I went to 3 stores to finally find a place that carried the material I needed for the flapper gasket...a tip for anyone else having problems go to a car upholstery shop if they don't have it they may have a source.
04-11-2016, 11:29 PM | #24 |
Umm, I don't. What joke?
04-12-2016, 08:49 AM | #25 |
The caps on the nozels...popped right off no prob -
I was guessing you ment take them off before attaching the hose to them no?
