Squeaky/tapping noise on #8 cylinder
Hey guys, I'll give you a quick run down of what it is, and what's goin on. I'm gonna pull the valve cover after I post this and take a look.
It's a 1970 c10. Just did a top end on it, it's been an on going tuning lesson for me, and I think whatever is happening is part of the problem. New heads, cam and lifters, intake manifold. I went with a Comp 280H magnum cam. I used 1.5 roller tip rocker arms. I've been trying different timing settings to see what it likes, right now I'm at 34*. It's got 12* initial, and it has a GM performance HEI (not sure if the vacuum advance is adjustable on those) Drove it to town and it was running good, not great. Noticed a little knocking type noise at #8 this more but nothing loud. After I left the store, it was hard to start, had to hold the gas pedal to the floor. Idled funky and real low rpm so I brapped the throttle a few times to get it to idle. It went back to normal idle. Found a strait away coming home and accelerated hard but never letting it kick down, held 3rd gear, and it started studdering at about 3300rpm so I let off. Drove home ok, but it didn't like that hard acceleration at all. Stopped at the mail box and heard that same cylinder but now it was making a squeaking kindof noise with a tap. Definetly not an exhaust leak, and definetly the same cylinder I heard earlier when it was just a slight tap. What do you guys think? Keep in mind it was my very first top end, and I did it myself including the valve adjusting and setting preload. I'm gonna go pull the valve cover, thanks for any input guys |
Re: Squeaky/tapping noise on #8 cylinder
Matt, my first thought was bent pushrod as I opened the post and started reading then my mind has gone to bearing on the crank[ spun rod] the hard to rev and not wanting to rev up is scary to me. Jim
I'd get both pushrods on the base circle (TDC for that cylinder) and double-check the lash, make sure one isn't too loose to too tight.
Too loose could cause the tapping; too tight could cause the idle. Not sure what could cause both, but check then for straight like Hugger said as well (roll them on a flat surface).
I hadn't considered a bearing but that would make sense given the squeaking sound. Here's more of what I know as of now. It makes the noise in rhythm with the firing sequence, almost like it's making the noise when #8 fires, so I'm hoping that means the bearings are ok and that this is a pushrod or valve adjustment issue. I'm pulling the rocker arms off of #8 right now so I'll know more about the pushrods soon. Thanks for the quick reply Jim!
#5 | |
Ok pushrods from #8 are showing me some terrible stuff going on. The looks like the end of one has been ground off, it's significantly shorter than the other. The one that has a ground off end is the intake side.
Top view
Somebody break the news, how bad is this? Neither one is perfectly straight when rolled on the table. Very very slight bend it seems, because when rolling slow they pick up speed on there own then slow down, then go faster again, then slow down (all in about 12" of rolling and very slow obviously)
What could cause the end to grind off? Is this just a pushrod replacement of are the lifters coming out? Bad lash adjustment maybe? |
Closer pic
![]() Join Date: Oct 2009
well, it aint "good" - which end of the push rod is that - lifter or rocker? Either way, you've technically got some metal in the motor floatin around. Question is whether or not it's fine enough (or if you're comfortable enough) to just drain it and refill... But for the base problem - sure looks like lash was perhaps set too tight - even if set on the base circle. What does the lifter (or rocker) interface look like? New valve springs?
#11 | |
Rocker
#13 |
Here's the underside of the valve cover, lots of fine metal dust over the #8 side
#14 |
I would guess that the amount of time and money going into fixing this is relative to what caused it. I did re-use the pushrods it had in it, so maybe this is just confined to that one cylinder. If it's valve lash, this could potentially be happening to the other cylinders right?
Either way, they don't sell rockers by the pair so I'm buying a set of those. If this is lash, replace those two pushrods and leave the rest? Or buy a whole new set and do them all. Sheesh, I was all ready to move on to suspension! |
#15 |
If those are comp call them up and they will sell you one or a pair. Those guys are really pretty helpful. How big are the valve springs did you buy them with the cam[not just at the same time] but what I'm saying are they matched to the cam or are they real heavy or stiff for a BIG cam. That will eat up the rockers bend the rods and screw over the lifters and if the springs are too to heavy for the cam it will wipe the lobes off of it. Now where you are now I'd run the valves again and make sure you have the valves adjusted right to a little loose. The spec @ zero lash has been 3/4 to 1 and 1/2 turns on the rocker nut after zero lash, I caution on the loose side and go between 1/2 to 3/4 of a turn. Matt what was your oil pressure gauge saying while all of this was going on? Did it ever drop low or has it lowered lately?
#16 | |
As for the valve springs, they are pretty heavy, but when I bought the cam I also got the matching part number for springs so they should be spot on. The rockers are made by Comp but sold under a different name. I'll check with PWR or PWM or whatever the companies name is about replacing a couple Last edited by Mrturner1; 04-06-2016 at 08:52 PM. |
#17 |
PRW! That's the company, I couldn't remember but I was close lol
#18 |
Might be time for a new set of hardened pushrods too. The old pushrods have worked well and I saved a bit of money, but I have a feeling that this could have been a lot worse than it is.
Motor revved fine, but it was studdering when I accelerated pretty hard at about 3300 rpm |
#19 |
Is this definetly a valve lash adjustment issue? Or is there something else that could have ground off the pushrod like that?
#20 |
Likely a lash issue. That rocker got a bit loose allowing the rod to wiggle around inside the cup.
Have not seen where rocker nuts were mentioned. Did you buy new ones? Stock ones should not be re-used. Unless you swedge them again. Otherwise they will tend to back off.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#21 |
I've seen cases where a cam lobe started to wear due to improper break in of the cam, once the cam wears a bit the excessive clearance can wear the pushrod and rocker like that. Or using too heavy a valve spring during break in of cam as well can cause issues.
#22 | |
#23 | |
During the cam break-in, I got about 10 minutes in at 3200 rpm and a belt broke. So the next day I got a new belt and gave it 20 more minutes. I thought no big deal, but it's my first so I could be wrong. |
#24 | |
As for the metal bits you'll have running through the engine well that's a problem I'd look at after adressing this issue and considering what you can live with. You could change oil and filter a couple times and hope for the best or start over. But if the cam is going flat you're starting over for sure anyhow |
#25 |
![]() Join Date: Feb 2016
Might be wise to pull the intake manifold and check your lifters, or at minimum pull all your push rods to check them and drain your oil into a real clean container and hold it in the sun to see if there is any sparkly pieces or gray streaks. Also cut open your oil filter and pull out some of the pleated paper and look at it in the sun. You can also put a piece of the filter paper (several pleats folded together) in a vice and crank it down real tight with a clean white paper towel under it to catch what squeezes out. I do this on heavy equipment trans/hydraulic/eng oil filters and you would be surprised at what squeezes out.
If it is just the one push rod end there should not be much metal or gray material to find but if a cam lobe or lifter is going south there would be a bunch more. |
