04-06-2016, 06:33 PM | #1 |
What's This Bracket For?
04-06-2016, 07:10 PM | #2 |
Re: What's This Bracket For?
I think it's just a heat shield. They usually rust off on northern trucks. I need to find a good one for my V3500.
Nate
Current Project: 1990 V3500 CC dually. |
04-06-2016, 07:10 PM | #3 |
Double post.
04-06-2016, 07:21 PM | #4 |
04-06-2016, 07:42 PM | #5 |
Yes it's the part of the heat shield, helps keep your gas peddle area cooler
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
04-07-2016, 01:28 PM | #6 |
Dino burner
It is a heat shield, but it's on the passenger's side of the truck. It is designed to keep the heat from the exhaust-mounted heat riser valve from transferring to the passenger compartment.
04-07-2016, 04:14 PM | #7 |
Came in handy for me, attached a clamp for my LS swap fuel lines to that piece.
04-07-2016, 04:24 PM | #8 |
04-07-2016, 09:27 PM | #9 | |
Sorry I bad. I was looking at the pic again I put down the wrong side.
