Old 09-26-2003, 09:58 AM   #1
Dan72cst
Dan72cst's Avatar
Axle swap question
I am fairly new to the 4x4 world and have a question. I have a project 68 K20 that has a closed nuckle drum brake dana 44 (i think) up front and an Eaton in the back. I found a screaming deal on a corporate 14 bolt for the rear (4:10 ratio). What would be a good disk brake open nuckle front axle to swap in and what vehicles/years did they come in? I've heard Dana 60 fronts are the ultimate, but don't really want to spend that kind of cash. Thanks
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 09-26-2003, 12:26 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
71 or newer for open knuckle/disc. 73 or newer same as 71/72 except the u-joint is larger. These are dana44. Or a 8 lug 10 bolt from 78 or newer there about. One thing to watch the caliper banjo fitting changed from standard to metric at some point, so the brake lines are not interchangeable if you get the wrong one. You will not be able to use the drum brake lines(flexible).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-26-2003, 02:10 PM   #3
Dan72cst
Dan72cst's Avatar
Thanks JIMs70GMC,
So a Dana 44 or 10 bolt. Do you know what year would most likely have 4:10 or how to tell quickly without pulling the cover?
Can you tell easily if the brake lines are metric or not?
Old 09-26-2003, 06:07 PM   #4
1969 GMC
1969 GMC's Avatar
551 ivory/gold? isn't that a 50th??
I want some pics!!
Also, the 10 bolt replaced the dana 44 but I think the 44 is stronger. 4.10 is a common gear ration in 3/4 4x4's.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-26-2003, 06:20 PM   #5
ckhd
ckhd's Avatar
ME TOO! I've been told there aren't any K20 50th anniversaries out there! I want a glovebox sticker pic too!
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 09-26-2003, 11:59 PM   #6
1969 GMC
1969 GMC's Avatar
ckhd, check out longhorn man's website...there is a pic of K20 50th on there somewhere. they are really rare.
1969 GMC K2500
1996 Honda Accord
Old 09-27-2003, 02:14 AM   #7
Dan72cst
Dan72cst's Avatar
I'll try a picture of the build sheet....Its the second option from the bottom on the right hand side.
The PO stripped and painted the glove box door, so no sticker.
It really didn't have a lot of options for a 50th, but had the two tone paint scheme and is a Custom and best of all its a K20.
I don't have any pictures of it. It really is a basket. Completely stripped, bed full of parts, The frame is painted, waiting to go back together.
Old 09-27-2003, 02:03 PM   #8
1969 GMC
1969 GMC's Avatar
i just read somewhere else on the board that it needs to be a Custom or CST to have the 50th package. Sounds like you have one!
1969 GMC K2500
1996 Honda Accord
Old 09-27-2003, 04:41 PM   #9
ckhd
ckhd's Avatar
Actually, the exterior and interior colors are the only requirements for a 50th. It seems that most are customs and CSTs, or custom campers, etc... It also seems that they either have a 327 or a 396, AC, etc... I think that people who special ordered them, or the dealers that ordered the 50th package also wanted bells and whistles to go with it.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
