Old 04-06-2016, 09:53 PM   #1
Rollinsqrbdy
Rollinsqrbdy's Avatar
350 motor mounts
So I recently purchased a 64 short wide. Boy it needs a lot of work but $300 bucks was a good deal. At least I think. My problem is I got a good 350 I wanna put in but air transportation sure which mounts I need. Their no mounts on their right now so where can I pick up a pair? I'd like a new set. I don't really wanna get some of ebay. Thanks for any help
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 04-06-2016, 10:31 PM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: 350 motor mounts
are you saying you don't have the frame mounts that hold the motor mounts.Well you might be better off then me i bought a 1964 short bed Fleet side for 2500.00 But the body is straight straight tail gate.But i hated the small window so i traded a 3/4 ton that was a camper special for mine I own both trucks but sold the truck a year later and he wanted the big window.
So i got my big window with my new cab and core bushing support bolted fore free YAA Here have a look this is before i had the cab swapped.Been driving a 1965 with a small window for 20 years wanted a small window for the short bed
stsalvage is offline   Reply With Quote
Old 04-06-2016, 11:01 PM   #3
Rollinsqrbdy
No mounts what so ever. Only the cross member that goes accross. I'm new to this body and got a lot to learn
New Mexico Member
Old 04-06-2016, 11:03 PM   #4
Rollinsqrbdy
Stsalvage- nice truck. Looks Lot like mine. I'll post pics Inow the morning
New Mexico Member
Old 04-06-2016, 11:59 PM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
I;m looking to see if i have any pics of the motor frame mounts you need EBAY is your best bed or Craigslist
I will take better pics tomorrow when i get home I only have 1 truck that dose not have a motor in it but i will give you somthing to look at now but they will be better tomorrow
Old 04-07-2016, 01:15 AM   #6
Captainfab
60-66 Nut
If you want to use the original style engine mounts, you will need the frame brackets from a '63-'66 with a 230/250 I6 or a V8, or from a '67-'72 with a 230/250 I6. The engine mount itself can be purchased at your local auto parts store. '63-'72 with any I6 or small block V8. If you can not find the frame brackets locally, check the '60-'66 classifieds here on the forum. These would be the easiest if you are staying with a manual trans.
If you are converting to an auto trans and want a better engine mount, you will need the frame brackets from a '73-'87 C20 or C30. Then you will also need the engine mounts themselves plus the upper part often referred to as a 'clamshell'
Old 04-07-2016, 08:11 PM   #7
Rollinsqrbdy
This is what I got to work with...I'm new to the 60-66 c10 body style so I got some learning
New Mexico Member
Old 04-07-2016, 08:38 PM   #8
Rollinsqrbdy
Ok so will the frame brackets outta a 79 k10 work, or does it have to be the c10 brackets
New Mexico Member
Old 04-07-2016, 11:50 PM   #9
Captainfab
60-66 Nut
The K series engine mount brackets are a completely different animal.......4wd versus 2wd.
As I stated above, you want the brackets from a '73-'87 C20 or C30. Those will fit the early frames better than the brackets from a '73-'87 C10.
Old 04-08-2016, 12:51 AM   #10
shortstep60
IF you need the motor mounts I have a 65 with a 283 I am parting out just let me no thanks.
shortstep60 is offline   Reply With Quote
