Old 04-06-2016, 10:07 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Valve Cover Gasket Choices
I need to replace my valve cover gaskets and am wondering if anyone has used the Fel Pros in my link or I'm open to any other suggestions.
http://www.fmmotorparts.com/fmstoref...t#.VwXAHWO4J0c
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-06-2016, 10:22 PM   #2
Already Gone
I need to replace the valve cover gaskets on my truck ,72 C10 with stock 350, and was thinking of these in the link. Has anyone used these and if so how good/bad are they. If someone has a different choice please
post.http://www.rockauto.com/en/moreinfo.php?pk=128425
Old 04-06-2016, 11:15 PM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Valve Cover Gasket Choices
I just put them on my 1965 3/4 ton stay away from cork that old technology.You will spend 39.00 to 50.00 a set But well worth it
stsalvage is offline   Reply With Quote
Old 04-06-2016, 11:58 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Thumbs up Re: Valve Cover Gasket Choices
Those are the only gaskets I use. Perma dry plus. Just installed a set on my 68 a few days ago in fact. Expensive but worth it...no leaks. No sealant required...just torque to 3ft lbs.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-06-2016, 11:59 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by stsalvage View Post
i just put them on my 1965 3/4 ton stay away from cork that old technology.you will spend 39.00 to 50.00 a set but well worth it
x2
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-07-2016, 01:11 AM   #6
OregonNed
OregonNed's Avatar
Had great luck with these and my new aluminum covers. http://m.summitracing.com/parts/fel-1604
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-07-2016, 01:56 AM   #7
Ringo934
Ringo934's Avatar
I use the Perma dry plus as well. No problems to report. I believe they are supposed to be reusable; Although, I have never reused them.
1969 GMC C/1500 LWB Wideside
355 SBC/TH400/3.73 posi-traction
Daily Driver.
Carburetors, because I don't care to consort with that of the robot race.
Ringo934 is offline   Reply With Quote
Old 04-07-2016, 01:59 AM   #8
Foureye71
Foureye71's Avatar
I also have these and haven't noticed any leaks.
'71 K1500 Short-Wide
Foureye71 is offline   Reply With Quote
