Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-07-2016, 07:22 AM   #1
A1971Blazer
A1971Blazer's Avatar
welding advice from pros...?
I'm making these anodizing racks for my buddy's plating shop.....10" diameter ¼" wall aluminum tube with teeth machined on one side for contact points......
¼" x 2½" flat bar machined with a radius and 45º chamfer on one side.....
I'm a machinist, not a welder......what do I need......(besides a steadier hand).....to do different on these welds?
I'm running AC high frequency at 165 amps using 5356 1/8" filler rod and 3/32 tungsten shaped to a ball end.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 04-07-2016, 11:23 AM   #2
ERASER5
ERASER5's Avatar
Re: welding advice from pros...?
Pre-heat the whole thing in an oven or use a gas torch. Aluminum pulls the heat away from the weld extremely fast and that affects the weld.
You are wire brushing or wiping with acetone before weld right?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-07-2016, 11:27 AM   #3
A1971Blazer
Yes.....I forgot to add that I am pre-heating with a map gas/propane torch, also yes I'm cleaning with a wire brush and acetone prior to welding.......the welds are strong...I did a destructive test on one....the weld held just fine.....just wanted them to look a little better............looks doesn't matter much on these but I want to do some aluminum stuff for myself soon.
1967 C10 Step side
1968 C10 Step side
Old 04-07-2016, 08:28 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Honestly, I don't see a ton there thats "wrong". It looks like the lower-side of both welds looks like it didn't get super deep penetration (its the shorter "leg" of the weld and the hard edge). Clearly though, you kept a fairly steady heat and travel speed, because you welds aren't drastically different from each other.
The top side welds look a little colder than the inside joint. Preheat helps with that, but travel and feed speed can help you make up for that a little. Worst case scenario (preheat not helping and amps not helping), you can always have a helper keep a torch on it to keep the preheat up while welding.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
