04-07-2016, 08:29 AM | #1 |
Project Pigpen 1951 5 window 3100
So here is an introduction to my current project. 1951 Chevy 3100 5 window. The truck is from Kansas and the plate on it expired in 1982. Pretty solid and complete truck. typical broken glass, rusty floors and cab corners but pretty much all there. Plan is Mustang II front, 4 link rear, LS motor, and air ride. I don't plan on painting it. And the due date is early June, I really started on it August of last year so that's not as bad as it sounds.
04-08-2016, 08:39 AM | #2 |
Re: Project Pigpen 1951 5 window 3100
04-08-2016, 08:58 AM | #3 |
Nice progress so far.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
04-09-2016, 12:49 AM | #4 |
nice progress, is that crew cab long bed SRW a factory truck? gotta be a unicorn (one of one)
I see the SG on the tag, did it come from around wichita?
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
04-09-2016, 09:28 AM | #5 | |
Yes the truck is from somewhere east of Wichita. |
04-10-2016, 08:58 AM | #6 |
Looking good pigpen.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
04-11-2016, 12:41 PM | #7 |
The fleet: 2014 Ram 1500 Express, ya its a Hemi 2009 Jeep Liberty Sport- the wife's ride 2000 Chevy C3500- the work horse 1972 Plymouth Custom Suburban Wagon 5.7 Hemi swap 1951 Chevy 3100- project pigpen |
04-11-2016, 12:42 PM | #8 |
04-12-2016, 03:37 PM | #9 |
Looks good....following
04-12-2016, 06:56 PM | #10 |
Mustang II front crossmember, boxing plates, tubular arms, 2" drop spindles, 5 x 4.5 bolt pattern rotors, 2500# Firestone bags. Ford 8.8 rear end out of an Explorer, generic four link kit, C-notch, 2600# Firestone bags. It's just tacked together in this pic to make sure everything fits right.
Other cab corner.
04-12-2016, 11:32 PM | #11 |
Nice start to the chassis. Can't beat the Ford 8.8 out of an Explorer. Very strong rear end.
04-25-2016, 08:00 AM | #12 |
I tore the rear end down for new seals and gaskets.
Made motor mounts and checked motor and cab clearance. I ended up modifying the headers to clear the frame. I'm using a steering column from a square body S10, pedal assembly from a 1999 Jeep Grand Cherokee. The start on modifications to the firewall for all that. 1955 Bel Air wheel, S10 bench seat. This is as far as I went with mockup before taking all back apart to sandblast and paint the frame.
04-25-2016, 08:02 AM | #13 |
04-25-2016, 08:08 AM | #14 |
Satisfied everything was going to fit, I took back apart to finish weld everything.
Sandblasted, Por15, and top coated the frame. and reassembly started.
04-27-2016, 07:48 AM | #15 |
I sectioned my deep truck oil pan about 1.25" and tig welded it back together. It doesn't leak but it was a real pain.
Engine and trans in the frame for the final time. My DIY harness.
04-27-2016, 10:10 AM | #16 |
Like how you are doing this, will tag along for the build...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
04-27-2016, 10:45 AM | #17 |
Just read this.
You take it seriously Very nice work so far!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
04-27-2016, 10:50 AM | #18 |
I like where your headed with this, nice work!
05-10-2016, 08:19 AM | #19 |
05-10-2016, 08:39 AM | #20 |
And the first start before I put the cab on.
https://youtu.be/unPKwqiN0cs
05-12-2016, 03:05 AM | #21 |
Looks great. What radiator are you using?
05-12-2016, 07:25 AM | #22 |
I'm using Speedway Motors Part # 9175159 for the radiator. I had to modify the top of the radiator support to get the radiator as far forward as I wanted it. I didn't want to use an electric fan or a shallow oil pan so I ended up mounting the motor higher and farther back in the chassis than most. the down side of that was that I had to add clearance in the fire wall for the back of the valve covers and my transmission tunnel is bigger.
06-02-2016, 04:59 PM | #23 |
Primed and painted inner fenders and core support.
started wiring using my DIY engine harness and a Speedway Motors kit gauges are from dolphin
06-02-2016, 05:02 PM | #24 |
06-03-2016, 01:29 PM | #25 |
Lookin good
my 54 s10 build |
