Old 04-07-2016, 10:57 AM   #1
joe dirt
joe dirt's Avatar
1961 front crossmember mount
my 61 currently has a 350 in it,..was that way when I got it,..but what is this mount circled in red originally for?..was it a 6cycl mount?
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 04-07-2016, 10:58 AM   #2
joe dirt
joe dirt's Avatar
Re: 1961 front crossmember mount
oops
1964 c10 swb
Old 04-07-2016, 11:23 AM   #3
62stepside longbox
62stepside longbox's Avatar
I have that Same mount on my 62 w/ straight six. I believe it's called the horseshoe mount. It also has the bellhousing mounts.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-07-2016, 11:53 AM   #4
joe dirt
joe dirt's Avatar
so the forward mount is the factory six mounts and the one on top of the xmember is v8?
1964 c10 swb
Old 04-07-2016, 02:01 PM   #5
slepysal
slepysal's Avatar
I believe the forward mount was for the V8 horseshoe mount
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-07-2016, 02:07 PM   #6
joe dirt
joe dirt's Avatar
i currently have the horseshoe mount and the forward mount isnt used
1964 c10 swb
Old 04-07-2016, 02:07 PM   #7
62stepside longbox
I have the front horseshoe mount with my straight six. they can also be used with v8 and straight six. Are you using the Side mounts as well?
Old 04-07-2016, 03:41 PM   #8
padresag
I6 more than likely went forward and the sbc was the back one seeing as the I6 is longer
ron
padresag is offline   Reply With Quote
Old 04-07-2016, 04:20 PM   #9
Brad54
Brad54's Avatar
Holes in the top of the '60-'62 cross member, and the perch in front of it, are for the horseshoe mount.
The bellhousing mounts don't move--the trans is in the same location for V8 or I6.
The I6 is longer, so the perch was added to mount the I6 with the horseshoe.
The same horseshoe works with both the I6 and the V8.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 04-07-2016, 04:46 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
This is from an earlier thread :
Originally Posted by LostMy65 View Post
I had never seen the 'Horseshoe' engine mount thingy.
My 62 donor didn't have one. Mine was a V6 so it had two lower side mounts fabbed as part of the frame.
Here is a pic I found of the Horseshoe engine mount.
66 C20 Service Truck:
