Old 04-07-2016, 04:19 PM   #1
murguia
speedometer and mileage tracker not working
The original speedometer and mileage tracker have stopped working on my truck. Would this more than likely just be a new speedometer cable?
murguia is offline   Reply With Quote
Old 04-07-2016, 04:21 PM   #2
willem445
willem445's Avatar
Re: speedometer and mileage tracker not working
Most likely something with the speedo cable. My speedometer did work when I began working on my truck, found out the cable was shot where it connects to the tranny. New cable fixed it
willem445 is offline   Reply With Quote
Old 04-07-2016, 06:47 PM   #3
Nodnarb76
Nodnarb76's Avatar
After dealing with this multiple times on my Suburban, I would guess lower speedometer cable. When replacing it, make sure the cable is nice and straight without any bends in it.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 04-07-2016, 07:18 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
If you have one of those gear ratio adapters you might check that..I had one that went out on me once.. if you take it or the cable off you can run it with a drill and check it.
Old 04-07-2016, 07:31 PM   #5
murguia
awesome, thanks guys. Gonna give a new cable a shot. Does the fact that my track has cruise control make any difference, other than it running from the CC to the trani
Old 04-07-2016, 07:53 PM   #6
chrismoore701
chrismoore701's Avatar
Check your cable before you go buy a new one. Possible it just popped off Trans. Or popes out of back of gauge cluster
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
