Old 04-07-2016, 06:34 PM   #1
bh86
Flexplate question
I have a 5.3 out of a 2001 Tahoe and a4l60e out of a 1999 suburban with a vortec 350. The flexplate is slightly of it seems, do I need to redrill it or is there a different plate I need to buy?
bh86 is offline   Reply With Quote
Old 04-08-2016, 07:45 PM   #2
clinebarger
Re: Flexplate question
You have a 298mm Torque Converter & a Flexplate meant for a 300mm Converter.
The 300mm Converter bolt circle is a slightly larger Metric Pattern, 298mm Converters have a 10.75" Converter Bolt Circle Pattern.
I do not, Nor recommend "Slotting" the holes, Drill new holes like shown, (Black Dots).
You will also need a Crank Pilot Extension like this, http://www.summitracing.com/parts/sum-704004/overview/
clinebarger is offline   Reply With Quote
Old 04-09-2016, 12:05 AM   #3
69short
69short's Avatar
Will that spacer work for mating a 4l80e to a 5.3l that originally had a 4l60e?
69short is offline   Reply With Quote
Old 04-09-2016, 10:33 PM   #4
clinebarger
Yes, But GM makes a Flat Flexplate & Spacer for this If your running a Stock 6-Bolt (11.5" Pattern) 310mm 4L80E Torque Converter. Comes stock on '01-'07 2500HD Trucks.
When I convert from 4L60E to 4L80E, 99% of the time its in a vehicle that is performance oriented, So naturally it needs a Stall Converter, I have my Converter Shop build a 4L80E Converter that fits a Dished 300mm Flexplate.....So I don't have to deal with Spacers or Redrilling the Flexplate.
Old 04-15-2016, 11:15 PM   #5
bh86
I ended up just having my local trans shop build a torque converter for it, it was pretty simple since they're familiar with the LS swap stuff. thanks for all the helpful replies! It's getting closer to finished.
