Old 04-07-2016, 06:35 PM   #1
SRD art
Swapping Suburban Tailgate to Doors
Hey all. I did a search on the forum for this but didn;t come up with anything. I have a 77 Suburban with a tailgate and the window levers keep popping out of the plastic wheels in the tracks and the window falls down, most of the time it happens just while driving down the road not even raising or lowering it. I'm sick of farting with it.
I have a friend that has a late 80s parts Suburban with barn doors he said I can have. Is it a straight forward swap? Can I use all the parts off the parts truck or will I need to buy anything to make it work?
Thanks for any help. -Ben
-Ben,
Check out my website!
http://www.streetroddesigns.com
1977 C2500 'Burby w/454
1979 Olds Cutlass Pro Touring wagon "Pumkinator"
1985 GMC S15 Slammed Daily Driver & Autocrosser
SRD art is offline   Reply With Quote
Old 04-07-2016, 06:40 PM   #2
cfan10
cfan10's Avatar
Re: Swapping Suburban Tailgate to Doors
I don't think it is, I asked a while back on here and the answer was no, without fab work. But I wanted the tailgate instead of those barn doors.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 04-07-2016, 08:56 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Swapping bodies will be the path of least resistance for a swap from tailgate to barn doors. Otherwise you'll be sectioning in the quarters, roof and rear body panel.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-07-2016, 11:27 PM   #4
cheepin
What? I was going to do this yrs ago and the only difference I could tell was the bottom pan. The bolt holes are even already in the jambs.
http://67-72chevytrucks.com/vboard/s...ead.php?t=4379
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 04-08-2016, 05:53 AM   #5
D13
D13's Avatar
The reinforcements for the doors are not in the pillars.
Yes, the quarters are common. But all the reinforcements are different. So you essentially have to cut the back 6 inches off and swap them and weld them back in. Much quicker to do a full body post.
OP, easiest to fix/repace the tailgate. There's a nice metal bolt on panel that allows access to the window system.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 04-08-2016, 08:29 AM   #6
RandyP
RandyP's Avatar
I remember "back in the day" when we'd do repairs on 'burbs, if we just needed the outer skin of the quarters they were the same across the board. But if we needed the inner structure and had to buy the quarter assembly or (heaven forbid they forced us) a used quarter, it did make a difference in the type of rear door(s). Same for the rear body panel/platform panel, two different pieces available depending on door(s).
suburban tailgate, swap barn doors
