Old 04-07-2016, 06:57 PM   #1
1972 Jimmy
1972 Jimmy's Avatar
Where can I find AC evap insulation?
Hey guys! not sure if I'm calling this stuff correctly.... (insulation) I'm looking to put my A/C unit back in and I can not find any place that sells this stuff that insulated the evap tube coming out of the AC box.
Thanks,
Eric
1972 Jimmy is offline   Reply With Quote
Old 04-07-2016, 07:19 PM   #2
Jrainman
Jrainman's Avatar
Re: Where can I find AC evap insulation?
your local HVAC supply house , tell them the OD of tubing you want to cover ( Rubatex) is the name and or company that makes the best quality of this insulation and this is what it is called in general, But if you must know what the actual correct name, If I remember rite Polyzthylene Thermal insulation and I am sure I did not spell it correctly
Jrainman is offline   Reply With Quote
Old 04-07-2016, 07:22 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Where can I find AC evap insulation?
Here you go!
https://originalair.com/refrigerant-tape-18-length2
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-07-2016, 07:28 PM   #4
1972 Jimmy
1972 Jimmy's Avatar
You guys rock! Thanks for the quick response!!!
