Old 04-07-2016, 08:12 PM   #1
thatguyJim
question about the p-47 raised cross member kit
Well to start off with i have 1969 GMC c10 lwb with a sbc 350. The original had bout all the p-47 kit and somewhat assembled it. the kit is made by thorbecke brothers. I been trying to call them for the past couple of weeks to get some answers, but they have been rude. Im bout ready chunk this cross member and get a stock one. I am also using stock upper and lower control arms. my question is how do you know the lower control arms are centered. There is no identification on the cross member or the blocks that bolt to the cross member. also there is not such pin that thor bros claimed. I am in the process of figuring how to post pictures.
thatguyJim is offline   Reply With Quote
Old 04-07-2016, 08:15 PM   #2
thatguyJim
Re: question about the p-47 raised cross member kit
this is the pictures.
Old 04-07-2016, 08:32 PM   #3
bbbc10
Diggin The SquareLife
there should be two pins on the lower cross shaft of the control arms an two hole in the crossmember mount that they go in, if u want to get rid of it pm me with what u want for it.
bbbc10 is offline   Reply With Quote
Old 04-07-2016, 08:41 PM   #4
thatguyJim
Pins that point straight up ? or engraved into the cross shaft?
Old 04-07-2016, 09:01 PM   #5
thatguyJim
I know the cross shaft has 2 holes in it....
Old 04-07-2016, 09:41 PM   #6
thatguyJim
ok i was digging around the boxes of new parts, and I found this bag with loctite and looks to be 2 pins. Are these it ? Is it one per side ?
Old 04-07-2016, 11:18 PM   #7
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
The holes on the cross shaft are just on the front. There should be a hole on the bottom front of the crossmember. Those pins will go in the clamping block and cross shaft. This pic is from Jason's Instagram. I'm surprised someone at his shop would have been rude, They are all some cool people.
If you wanna get rid of that crossmember and other parts let me know.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-08-2016, 02:32 AM   #8
andrewmp6
Thats sad when a company has bad customer support like that.
andrewmp6 is offline   Reply With Quote
Old 04-08-2016, 07:14 AM   #9
thatguyJim
Ok I bever noticed the hole, im just gonna take apart the front end today when I get off work to put the pins in. Thanks for the information.
