Parking light help
My park lights work when my switch is in the park light position but go out when the headlights are on. Is this normal?
Re: Parking light help
my 67 is the same wondered myself must be normal
Judging by your name you have a 69 and if so then no yours should stay on with the headlights. I have a 69 and mine stay on. If I'm correct only 67 has it where the park lamps turn off when the headlights are on.
My truck is a 69 but I have a painless wiring harness, aftermarket headlight switch (Advance auto parts) and I have a 68 front end on it. Would it be something in the switch or in the harness that makes the parking lights go out when the lights are on? I want them to stay on. Thanks for your help.
#5 | |
I found a thread that's some help as well. http://67-72chevytrucks.com/vboard/s...d.php?t=428826 |
#6 | |
![]() Join Date: Apr 2005
Just a little history on park lights. They were originally intended for just that, parking. In some states it is technically illegal to drive with just the parking lights on (I called them "be cools" back in high school). They were used to let other motorists know that the vehicle was parked and not in motion.
There is your worthless tidbit for the day. |
Old member
Somebody replaced the head light switch with a 67. They don't work when the head lights are on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Just FYI, moving the park light wire to terminal 3 in the connector took care of my issue.
