04-07-2016, 10:43 PM | #1 |
'48 3800 front suspension question
I have a 1/2 ton front suspension from a '52 Chevy. Has anyone tried to swap this over to a 1 ton? I'm aware of the frame width being different, which could complicate things, but don't know what else may pose a problem.....any help is greatly appreciated. Thanks for your help!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
04-07-2016, 10:50 PM | #2 |
Hollister Road Co.
Re: '48 3800 front suspension question
What are you trying to accomplish by swapping axles?
04-08-2016, 05:03 PM | #3 |
Honestly, I'm trying to go from work vehicle to hotrodded. I dislike the way it rides in its current stock form.
04-08-2016, 05:19 PM | #4 |
Hollister Road Co.
I don't think you'll get much better with a 1/2 ton axle. You could go with a less stiff spring if you want to keep the straight axle or an IFS coil spring front end. But a straight axle hitting a pot hole is rough 1/2 ton or 1 ton. IFS is better
04-08-2016, 05:36 PM | #5 |
I was just sure you were gonna tell me that...lol
Thank you for the input....I do prefer if for sure. Just have to figure out the keep or upgrade question.
04-08-2016, 07:18 PM | #6 |
The only real advantage to the 1/2 ton is you can upgrade to disc brakes easier....
04-08-2016, 10:42 PM | #7 |
Hollister Road Co.
Not anymore. We make a 3/4 and 1 ton disc conversion that a bolt on like the 1/2 ton but with 8900lb GVW brakes
04-09-2016, 03:48 PM | #8 |
The front frame of a 3800 truck is slightly narower than that of a 1/2 or 3/4 ton truck. With that being said, the 1/2 and 3/4 ton trucks use a 1.75" spring vs. a 2" spring.
As long as the center pins on the 1 ton and 1/2 ton are the same, I can't see why it wouldn't work. You may have to clearance the holes in the 1/2 ton axle to use with the 2" u-bolts. Just my $.02 worth. Chris |
