Old 04-08-2016, 01:27 AM   #1
drewbert41
drewbert41's Avatar
Silicone on rocker arms
There is silicone on my rocker arms from PO doing a sloppy job putting on the valve covers. Should I try and remove this or just leave it as undisturbed as possible?
drewbert41 is offline   Reply With Quote
Old 04-08-2016, 01:40 AM   #2
swamp rat
swamp rat's Avatar
Re: Silicone on rocker arms
My thoughts are if you can do it get it out asap! all it takes is a piece of the stuff to plug a return galley or a bunch of it to partially plug the pick up screen on the oil pump... even smaller pieces that make it past the pick up screen and past the oil pump could create havoc in the oil ports feeding the lifters.. Can cause some problems.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-08-2016, 01:43 AM   #3
drewbert41
drewbert41's Avatar
Looks like it will come off in pieces. I guess I need to just make sure not to drop any.
Old 04-08-2016, 12:52 PM   #4
davepl
davepl's Avatar
Probably worth an oil change when you're done, if you're anywhere near due!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-08-2016, 01:03 PM   #5
summitflier
summitflier's Avatar
At first I thought you meant silicon lube. I'm guessing you mean sealer.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 04-08-2016, 02:41 PM   #6
drewbert41
drewbert41's Avatar
Yeah black sealer.
Old 04-10-2016, 09:50 AM   #7
Daman
With gasket technology these days I wonder why anyone would use silicone for anything on an engine except a dab to hold the water pump gaskets in place.
Maybe the front and rear of intake also. (A friend just replace his and it came with a small tube of silicone instead of the front and rear rubber gaskets)
Daman is offline   Reply With Quote
