04-08-2016, 03:16 PM | #1 |
70+ ( Old Skool Club )
Help with Spark Plug Choice
I am going to change the plugs in my bone stock all original 72 c10 with a 350 4bbl. and 87,000 miles. If I keep the truck 10 more years I may, at the most, put 10/15,000 miles on it over that time. Other than installing the Pertronix Distributor, ignition wires and one of their 40,00 volt coils I have waiting to be installed and maybe putting a dual snorkel air cleaner on the truck in the future the engine shall remain stock. My research has told me there are 4 different types of plugs, copper, platinum, double platinum and iridium. The prices vary from 1.89 for copper plug to 8.25 for the iridium. Can you guys/gals give me some real world info on what you are using for plugs. If my old memory is functioning correctly I believe that unlike todays vehicles the plugs in these engines form the 70's needed plug changes every 10,000 miles
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-08-2016, 04:00 PM | #2 |
Old member
Re: Help with Spark Plug Choice
Stock truck and having no issues I would stick with what's already in it.
R45TS plugs
04-08-2016, 04:08 PM | #3 |
Andy do you mean don't change them or replace them with what is already there.
04-08-2016, 04:26 PM | #4 |
i'd check them to see what the condition is first
04-08-2016, 04:44 PM | #5 |
Old member
I would pull them out and look at the burn on them. If they look good go with the same thing.
Back when I had the stock 307 I changed them every 15,000 but I would pull them and wire brush them good also if I thought I had a bad one.
04-08-2016, 04:45 PM | #6 |
The Niner
I go against the grain and have always run Autolite 24 Copper Core plugs.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
04-08-2016, 06:21 PM | #7 |
Its funny you mention the Autolite plugs. Not knowing what wa sin the truck and how long they'd been there I went and pulled the one closest to front on drivers side and her it is . Its an Autolite # 26 and looking at it I think the electrode looks like it should but I would guess it has been in there a long time.
04-08-2016, 09:43 PM | #8 |
I would go with the ac plugs and don't forget to open the gap for the electronic ign to .045 should get you 15 easy if everything else is good . back then tolerences and points weren't as good as they are now 100,000 was a worthless engine now its nothing that's why plugs had to be changed so often . I do still have a spark plug cleaner I use for points
