Old 04-08-2016, 04:17 PM   #1
Brad54
Brad54's Avatar
What year for Push-Pull power steering box?
I'm going to start on the '62 K10 build this summer, and wondered what years I need to look at for a Push-Pull power steering box?
Not interested in a cross-steer conversion... trying to keep things simple, and keep costs down using what's already there.
Thanks,
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 04-08-2016, 07:35 PM   #2
kwmech
Re: What year for Push-Pull power steering box?
Late '68 1969 for sure was the beginning
kwmech is online now   Reply With Quote
Old 04-08-2016, 11:09 PM   #3
dieseldude4bt
Are you upgrading axles also? going disk brakes on the front? Use what ever box came on the truck with the axle.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 04-09-2016, 08:07 PM   #4
Brad54
Brad54's Avatar
No, I'm not upgrading the front axle... gonna keep costs down and keep things simple by just rebuilding what I've got, at least for now.
Drum brakes, closed-knuckle D44.
I've got two: one in the truck, and one that was retrofitted into a '56 GMC that a friend gave me. Between the two of them, I should have enough parts to make a good axle assembly, without spending a ton of money.
I figure swapping steering boxes to PS isn't a real expensive proposition.
-Brad
Old 04-09-2016, 09:39 PM   #5
dieseldude4bt
Any Chevy or GMC 4X4 power steering box up to about '87 , later on one tons and suburbans, should work then.
Old 04-10-2016, 11:58 AM   #6
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
1981 the Saginaw boxes went to Metric fittings so stay with something older than 1981
DirtyLarry is offline   Reply With Quote
Old 04-10-2016, 12:03 PM   #7
dieseldude4bt
You can still use them just need the correct hose and pump.
