04-09-2016, 12:29 AM | #1 |
Glove Box Question?
I am new to these trucks but I was wondering is the glove box suppose to spring open when you push the button or are you suppose to grab it by the top side and open it with your hand like mine.
04-09-2016, 12:48 AM | #2 |
Re: Glove Box Question?
On mine, which is now removed, it didn't exactly spring open. It's just a release. In other words, grab it by the top side and open it with your hand like yours
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-09-2016 at 01:30 AM. |
04-09-2016, 01:48 AM | #3 |
There should be a spring-like mechanism that causes the door to drop open when the button is pushed and released. It's the wire-like thing (sort of a mini torsion/sway bar arrangement) that can be seen in the picture below. It extends from side to side and looks the same at both ends. The door doesn't exactly spring open, but you shouldn't have to pull the door to open it.
04-09-2016, 06:12 AM | #4 |
Now that I think about mine, which I have to physically grab at the top after pushing the button, that my long hinge/spring must be worn out or broken/out of shape. Kind of annoying but I don't open it much. I may need to replace it some day if it isn't a royal pain to do so..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-09-2016, 10:43 AM | #5 |
FirstOwner69,
Thanks for the info, mine is not there so I guess I need to locate one, any ideas where to find one? 18Z |
04-09-2016, 11:05 AM | #6 |
All about them K’s
I'm sure someone has one on the parts board. Post a wtb.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
04-09-2016, 11:51 AM | #7 |
Found one Thanks!
04-09-2016, 12:16 PM | #8 |
I misunderstood the question, as I didn't realize you had to pull on it. Of course you have to guide it down. Otherwise you're not doing your panel any favors, which is where I thought you were going.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-09-2016, 12:17 PM | #9 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-09-2016 at 12:26 PM. |
04-09-2016, 11:09 PM | #10 | |
If the spring is there and placed correctly, lube is always a good idea. |
04-09-2016, 11:35 PM | #11 |
Yeah mine wasn't there so I ordered a new bracket and it comes with the spring.
Thanks for the help and comments 18Z |
04-10-2016, 12:46 AM | #12 |
How come the end of my spring scratches the lower RH corner of my panel? Is that common? It's never been removed.
04-10-2016, 07:55 AM | #13 |
I'll have to take a closer look at mine today and see whats up.
04-10-2016, 04:21 PM | #14 |
04-10-2016, 11:56 PM | #15 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-11-2016 at 12:04 AM. |
04-11-2016, 12:09 AM | #16 |
I think the hinge captures the spring. It looks like yours has slid over. You need to get it back under the hinge.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-11-2016, 12:14 AM | #17 |
Here's a picture of mine from a different angle. Does your spring have the bend in it to form sort of a "foot"? You can see some slight wear from the spring rubbing but nothing like yours. If that foot broke off, it could leave a sharp end that would cause the wear. Your wear pattern also appears closer to the face of the dash which would be likely it the foot broke off.
04-11-2016, 12:51 AM | #18 |
Two additional pics. First is of the driver side of hinge. Second is a better shot of the passenger side taken from the center of the glove box door.
04-11-2016, 07:14 AM | #19 |
Not to hi-jack but thats whats wrong with mine, no springs, who sells them??
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
04-11-2016, 07:51 AM | #20 |
Thanks for posting this question... I'll have to look at mine. I know it pops open about half an inch maybe. And I only remember that because my son opened it the other day while we were working on the interior.
I know I use to have a 70 that you had to hold the button with one and and pull open with the other. Now you just have me curious. Like I said. Thanks for posting the question.
71 swb 350/4sp manual 5/7 static drop |
04-11-2016, 09:21 AM | #21 |
Good thread, I was wondering the same thing with mine!
04-11-2016, 01:10 PM | #22 |
Hamjet,
I bought a new hinge from Ecklerstruck.com and the spring comes with it, I haven't seen it by itself but that doesn't mean someone doesn't sell it that way. I think I payed $20 for the hinge and spring. 18Z |
04-11-2016, 02:50 PM | #23 |
OK, thankyou!
04-11-2016, 10:05 PM | #24 |
I've come to the conclusion the damage to the corner per the image I posted was not the result of the spring (sorry). A screw or similar must have slipped into the corner, and the damage was caused when the lid closed. On another note, the door latch plate wasn't screwed to the panel. The door operated without them, so they're probably for the liner, and were lost when the liner was removed. Unless someone advises differently, seems safe to believe the latch uses the same screws as those for the rest of the liner.
04-11-2016, 11:56 PM | #25 | |
