Old 04-09-2016, 09:59 AM   #1
JMac11
JMac11's Avatar
VSS Plug- Female
Looking for Female plug to fit factory VSS plug, hook up aftermarket VSS unit. Anyone know Part# or what on a donor vehicle will have one. The GM unit plugs into the VSS unit direct
JMac11 is offline   Reply With Quote
Old 04-11-2016, 10:39 AM   #2
dayj1
Re: VSS Plug- Female
Chances are that it's a Delphi branded connector. it's likely in their catalog (in the metri-pack section). Once you get the part number, you can use google to find a place to buy it. I personally use Mouser Electronics as they stock most of the Delphi connectors and terminals.
Here's a link to the Delphi catalog...
https://www.powerandsignal.com/docs/...%20Catalog.pdf
If you just want to go junkyard hunting, look at 4 wheel drive GM trucks. They have an extension harness to extend the VSS wires to reach the transfer case. That short extension harness will have the plug you're looking for. The only part that I can't tell you off the top of my head is if it is the '99 up body style that "LS" based motors originally came in or if the extension harness was used on the '88-'98 body style.
dayj1 is offline   Reply With Quote
Old 08-05-2016, 09:06 AM   #3
JMac11
JMac11's Avatar
Think this is it!! Opinions?
http://www.lsxtune.com/shop/product_...roducts_id/778
