Removing oil pressure line from bezel
Trying to get my dash bezel out and the last thing I need to get it off is the oil pressure line. I cant exactly tell how to get it disconnected.
Is it nut "A" or nut "B" that I need to disconnect to get the bezel off? Thanks. |
Re: Removing oil pressure line from bezel
B ...upside down and backwards is the only way to describe these....small wrench 5/16 I think shorter the better. Good luck...
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
Thanks notsolo!
Scrapper 1
trust me the B nut with a 5/16 lube it first if you can and your done Boy i love them manual gauges
Yes, 5/16, if it was like mine you need a good one, better yet see if you can get a flare nut wrench. Get ready for some cussin', and spitting, hair flopped up/wild eyed-scare the kids anger if it went like mine
![]() 72 K5 Blazer 72 K10 SWB (in pieces under slow construction!) 72 K20 |
